First 2023 update on my old Challenger
#3180780
10/03/23 09:58 PM
10/03/23 09:58 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Haven't touched the car all year until a couple of days ago...
It's loads of fun trying to find parts and tools that are still in hiding somewhere after the extensive water damage the house had last year. I own two (2) oil pump priming tools and can't find either of them. They're probably right next to the throttle cable bracket that also disappeared; lucky that I stumbled across one from AR Engineering that I didn't remember having.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: First 2023 update on my old Challenger
[Re: Brad_Haak]
#3180781
10/03/23 10:05 PM
10/03/23 10:05 PM
Brad_Haak
Loudoun County, VA
Gonna use a Braswell drop-base air cleaner assembly; mocked up the hood to check clearance with no spacer installed
[Re: Brad_Haak]
#3180785
10/03/23 10:19 PM
10/03/23 10:19 PM
Brad_Haak
Loudoun County, VA
Car is up on jack stands now since I've been doing stuff that requires being under the car. I let it sit on the tires for too long and appear to have flat-spotted my new M&H front radial skinnies... grrrr
Even though I've been second-guessing my decision to have the T/A scoop modified for an additional 1-1/2" clearance, it may be growing on me.
[Re: ZIPPY]
#3180869
10/04/23 09:33 AM
10/04/23 09:33 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#3180873
10/04/23 09:39 AM
10/04/23 09:39 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Looking good, if your front tires aren't ancient I wouldn't worry about the flat spot. Once the tire warms up I bet it goes away just fine. If the tires are old you should replace them anyways though.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3180894
10/04/23 10:48 AM
10/04/23 10:48 AM
Brad_Haak
Loudoun County, VA
Looking good, if your front tires aren't ancient I wouldn't worry about the flat spot. Once the tire warms up I bet it goes away just fine. If the tires are old you should replace them anyways though. No, not (that) old. I'm hoping this is a case where -- like you said -- the issue will go away when the tire(s) reach operating temp.
[Re: AndyF]
#3180895
10/04/23 10:50 AM
10/04/23 10:50 AM
Brad_Haak
Loudoun County, VA
Engine looks ready to go! Don't have my checklist in front of me at the moment, but It's getting closer << OK, wrong color, but ya' get the idea >>I'm waiting for all the unexpected sh!t to pop up when it's finally running again... oil leaks (engine? trans? diff? take your pick) ... brakes failure... electrical issues... all the fun stuff As long as it's not trying to imitate the Exxon Valdez, the first place it needs to go is somewhere yet determined to get the front end aligned after having replaced just about everything but the LCAs, and even they got new bushings
[Re: Al_Alguire]
#3180931
10/04/23 12:31 PM
10/04/23 12:31 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
Looking good. I almost went with the same hood until I decided to build my Shaker for my Challenger.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: moparx]
#3181326
10/05/23 12:26 PM
10/05/23 12:26 PM
Brad_Haak
Loudoun County, VA
^^^ There is a solid 1"+ clearance above that air cleaner with the modified hood scoop. I wasn't sure the Victor heads and TF (or Victor) intake would be able to use a decently sized air cleaner and still have room under the standard T/A scoop, plus I wanted the option to try different spacers knowing how the engine responded to them on the dyno. Big ugly scoop means room for adequate air cleaner system and ability to run at least a 1" spacer, too.
[Re: Brad_Haak]
#3181340
10/05/23 12:58 PM
10/05/23 12:58 PM
Posts: 4,688 On the parachute mount
n20mstr
^^^ There is a solid 1"+ clearance above that air cleaner with the modified hood scoop. I wasn't sure the Victor heads and TF (or Victor) intake would be able to use a decently sized air cleaner and still have room under the standard T/A scoop, plus I wanted the option to try different spacers knowing how the engine responded to them on the dyno. Big ugly scoop means room for adequate air cleaner system and ability to run at least a 1" spacer, too. BLOCK OFF the lower part of that scoop, the "good" air is 2" above the hood surface. That will also help cut down the drag since the opening is so large
....BAD A$$ STREET CAR.....
[Re: HardcoreB]
#3181796
10/06/23 10:12 PM
10/06/23 10:12 PM
Posts: 553 Kentucky
clovis
Kentucky
I’m digging that Barry Grant carb. After reading all your testing, I wound up buying one for myself.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#3181811
10/06/23 11:23 PM
10/06/23 11:23 PM
Brad_Haak
Loudoun County, VA
Thx; I figured BG has been out of business long enough that I can just say it stands for Brad's Garage now This was SUPPOSED to be the "It's running again!" post. Unfortunately, when we thought it was ready to fire up late this afternoon, we got slapped down by a couple of electrical issues and a coolant system leak. Probably won't get a chance to get back into the garage until Sunday, so now I'm the problems get resolved and actual fire-up happens before I gotta go back to work on Monday.
[Re: fast68plymouth]
#3182294
10/08/23 08:38 PM
10/08/23 08:38 PM
Brad_Haak
Loudoun County, VA
Can't get it to start and stay running. Effed with carbs, swapped plugs, messed with timing... not sure where timing is right now, since I can't put a light on it since it's not running. Pi$$er...
[Re: Brad_Haak]
#3182310
10/08/23 10:00 PM
10/08/23 10:00 PM
Brad_Haak
Loudoun County, VA
Mike Hynes and I are wondering if we wired the Crane HI-6 box differently than it was before. I gotta find the instructions and see if we jacked it up somewhere.
