8 Stack on a street car
#3181595
10/06/23 08:48 AM
10/06/23 08:48 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
just wanted to show Ya'll the proper linkage to use for a Street application 8 Stack EFI, the link bar that most come with will pull on the slave bank side as the engine heats up, it will cause that bank to run lean, the hotter it gets the more things expand & the more it pulls on the slave bank side, I would use this on Street OR race car. Its called Jack shaft linkage https://www.youtube.com/shorts/Vn8igQFrOis
Re: 8 Stack on a street car
[Re: CSK]
#3181600
10/06/23 09:12 AM
10/06/23 09:12 AM
Posts: 22,721 Bitopia
jcc
Bitopia
Always wondered how IR with butterflies effects the air flow distribution in the port at varying part throttle street situations.
[Re: CSK]
#3181639
10/06/23 11:17 AM
10/06/23 11:17 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Looks nice! My old F355 uses a bellcrank in the center-
[Re: INTMD8]
#3181642
10/06/23 11:21 AM
10/06/23 11:21 AM
CSK
Pattison Texas
I had made a Bell crank, ie Watts set up after I figured out what was happening with the lean bank, it worked good but I just preferred the Jack shaft set up for my application , I also had to connect my Trans pressure cable to it all & the JShaft set up worked better for me
