Edelbrock 1406 problems on my 340 Problem Found!!
#3180835
10/04/23 07:34 AM
10/04/23 07:34 AM
Posts: 26,022 United Socialist States of Ame...
tboomer
We recently rebuilt an Edelbrock 1406 carburetor for my 340. It was the electric choke model and we removed the electric choke and wired it open. The car starts instantly and sounds great! However I can't get it to idle below 1500 rpms..I have tried both idle screws on the carb to no avail. Is there something that should have been removed on the carb? Thanks! Ted ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Edelbrock 1406 problems on my 340
[Re: tboomer]
#3180838
10/04/23 08:15 AM
10/04/23 08:15 AM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
Fast idle cam stuck in place?
[Re: slantzilla]
#3180924
10/04/23 12:23 PM
10/04/23 12:23 PM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
Fast idle cam stuck in place? Good guess although if the choke is wired open should be OK UNLESS the linkage pieces were installed wrong. Either something is holding the throttle blades open (primary or secondary) or there's a decent sized vacuum leak. Has to be getting air from somewhere ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: tboomer]
#3180961
10/04/23 01:22 PM
10/04/23 01:22 PM
TJP
Omaha Ne
Thanks guys! I will look at it later. I do have a pipe plug in the bark port of the carb with thread tape on it. The other two ports on the carb go to the valve covers. Should be 3 on the front and one on the back. The rear port should be used for power brakes or other item needing a manifold vacuum source. The 3 front ports are for: Red: Ported vacuum for vacuum advance if used. if not plug Orange: PCV in one valve cover :NOTE: The other Valve cover needs an open breather or to be connected to the air filter base Green: Manifold vacuum. Can be used for multiple things requiring manifold vacuum but it too small for PCV. If not used plug. NOTE: good source for vacuum gauge when setting mixture etc. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Some will argue to run the vacuum advance off this port but I'm not going to get into that discussion as it is almost as bad as are you a democrat or republican and why? Myself? I'm an independent 🤣🤣🤣👍
[Re: TJP]
#3180983
10/04/23 02:04 PM
10/04/23 02:04 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Did you plug the vacuum port to the electric choke housing after you removed it? Manual choke carbs have a brass plug installed there.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#3181009
10/04/23 03:24 PM
10/04/23 03:24 PM
tboomer
Did you plug the vacuum port to the electric choke housing after you removed it? Manual choke carbs have a brass plug installed there. I will look. Thank you!
[Re: tboomer]
#3181024
10/04/23 04:40 PM
10/04/23 04:40 PM
Posts: 20,817 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
The way I was shown how to do it years ago to get the idle and mixture screws in the ballpark if you don't have a vacuum gauge handy is to gently bottom the mixture screws out one at a time and turn them back out in 1/2" turn increments looking for the fastest idle speed you can get on the tach and stop when moving them out more doesn't speed the idle up. At that point turn them back in towards the carburetor like 1/4 - 1/2 a turn at most. At that point the idle speed will be up so then you move to the idle screw on the right side linkage to lower the speed back down. This is good info.. https://youtu.be/_AgqTUJr8aM?si=4k0HkkAsHX1zWaU4Also these carburetors need the float drop in both directions to be set just right or they will do strange things when driving. The ones I have bought over the years I just take them apart before running them and verify that right away. Once you get them set up properly they will go many miles without having to do anything to them.
[Re: Azzkikrcuda]
#3181187
10/04/23 11:00 PM
10/04/23 11:00 PM
TJP
Omaha Ne
Did you plug the vacuum port to the electric choke housing after you removed it? Manual choke carbs have a brass plug installed there. I missed the part about him removing the choke ![spank spank](/ubbthreads/images/graemlins/custom/spank.gif) I think you likely 🎯 it
[Re: tboomer]
#3181343
10/05/23 01:00 PM
10/05/23 01:00 PM
TJP
Omaha Ne
There was no vacuum port there in the place where it is on a 1405. A 1405 is a manual choke carb that may or mar not have to port drilled. If drilled it would have to be plugged or a leak would result. The 1406 is the same carb but with an electric choke. It would have to have the port for the choke to function properly. Which do you have?
[Re: TJP]
#3181388
10/05/23 03:01 PM
10/05/23 03:01 PM
tboomer
There was no vacuum port there in the place where it is on a 1405. A 1405 is a manual choke carb that may or mar not have to port drilled. If drilled it would have to be plugged or a leak would result. The 1406 is the same carb but with an electric choke. It would have to have the port for the choke to function properly. Which do you have? 1406
[Re: dragon slayer]
#3181622
10/06/23 10:23 AM
10/06/23 10:23 AM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
I am still confused on his symptoms and he hasn't answered the question on throttle blade location. The car idles at 1500 rpm.
If you have a manifold vacuum leak, or throttle shaft leak does that make the RPM go high? All the leaks folks are taking about are below the throttle blades and would be additional air that leans out the mixture. None of those leaks pull in more fuel do they?
A little but I guaranty the throttle blades are way to far open, of course the cable might be holding it open too, remove it to see.
[Re: dragon slayer]
#3181850
10/07/23 08:24 AM
10/07/23 08:24 AM
tboomer
I had to change the bracket from a Holley to an Edelbrock. I looked at the throttle cable bracket and there is about a 1/4" difference in the length of the cable. I will adjust it and see what happens.
[Re: dragon slayer]
#3181905
10/07/23 12:11 PM
10/07/23 12:11 PM
tboomer
Something still not right, as cable opens front blades and the secondary opened by the linkage and flex spring after the front open. Unless cable was interfering with secondary operation. Just got it finished...It is idling around 800 rpms and sounds great! Thanks for everyone's help! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: tboomer]
#3182035
10/07/23 07:30 PM
10/07/23 07:30 PM
slantzilla
Park Forest, IL
Good job Ted! Looking forward to seeing this car someday.
[Re: TJP]
#3182095
10/08/23 07:13 AM
10/08/23 07:13 AM
Posts: 1,348 VA
dragon slayer
VA
Something still not right, as cable opens front blades and the secondary opened by the linkage and flex spring after the front open. Unless cable was interfering with secondary operation. Just got it finished...It is idling around 800 rpms and sounds great! Thanks for everyone's help! Looks like cudaman nailed🎯 this one while we were chasing out tails LOL I guess you did not read my first post ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) 1500rpm is way too high for a vacuum leak to cause. I questioned actual throttle blade position on my first post ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) But it does show how a group can be drawn down a rabbit hole.
[Re: dragon slayer]
#3182319
10/08/23 10:29 PM
10/08/23 10:29 PM
TJP
Omaha Ne
Something still not right, as cable opens front blades and the secondary opened by the linkage and flex spring after the front open. Unless cable was interfering with secondary operation. Just got it finished...It is idling around 800 rpms and sounds great! Thanks for everyone's help! Looks like cudaman nailed🎯 this one while we were chasing out tails LOL I guess you did not read my first post ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) 1500rpm is way too high for a vacuum leak to cause. I questioned actual throttle blade position on my first post ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) But it does show how a group can be drawn down a rabbit hole. My bad ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
