Re: Edelbrock 1406 problems on my 340
[Re: dragon slayer]
#3181850
10/07/23 08:24 AM
10/07/23 08:24 AM
Posts: 26,030 United Socialist States of Ame...
tboomer
I had to change the bracket from a Holley to an Edelbrock. I looked at the throttle cable bracket and there is about a 1/4" difference in the length of the cable. I will adjust it and see what happens.
[Re: dragon slayer]
#3181905
10/07/23 12:11 PM
10/07/23 12:11 PM
tboomer
Something still not right, as cable opens front blades and the secondary opened by the linkage and flex spring after the front open. Unless cable was interfering with secondary operation. Just got it finished...It is idling around 800 rpms and sounds great! Thanks for everyone's help! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: tboomer]
#3182035
10/07/23 07:30 PM
10/07/23 07:30 PM
Posts: 20,228 Park Forest, IL
slantzilla
Park Forest, IL
Good job Ted! Looking forward to seeing this car someday.
[Re: TJP]
#3182095
10/08/23 07:13 AM
10/08/23 07:13 AM
Posts: 1,349 VA
dragon slayer
VA
Something still not right, as cable opens front blades and the secondary opened by the linkage and flex spring after the front open. Unless cable was interfering with secondary operation. Just got it finished...It is idling around 800 rpms and sounds great! Thanks for everyone's help! Looks like cudaman nailed🎯 this one while we were chasing out tails LOL I guess you did not read my first post ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) 1500rpm is way too high for a vacuum leak to cause. I questioned actual throttle blade position on my first post ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) But it does show how a group can be drawn down a rabbit hole.
[Re: dragon slayer]
#3182319
10/08/23 10:29 PM
10/08/23 10:29 PM
Posts: 15,569 Omaha Ne
TJP
Omaha Ne
Something still not right, as cable opens front blades and the secondary opened by the linkage and flex spring after the front open. Unless cable was interfering with secondary operation. Just got it finished...It is idling around 800 rpms and sounds great! Thanks for everyone's help! Looks like cudaman nailed🎯 this one while we were chasing out tails LOL I guess you did not read my first post ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) 1500rpm is way too high for a vacuum leak to cause. I questioned actual throttle blade position on my first post ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) But it does show how a group can be drawn down a rabbit hole. My bad ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
