Yip, I’ve ran cracked heads even on claimer circletrack motors, back then you had no choice except hunt for other probably cracked heads. The eq heads were good. Did the op buy these heads assembled from eq? Eric I think would have stood behind them..
Yeah I did buy them "already assembled". The previous 2 sets of EQs id bought, Id gotten as bare castings and assembled myself. thats the first and last time I buy "fully assembled, ready to run" EQs.
I dont know, about the possibility of them standing behind them/// I parked it because I was so beside myself as it definitely wasn't my first engine build, wasn't my first time running EQ heads, but was my first engine overhaul that went south. I left it sit as my garage ornament/ and we got by on our other vehicles, at one point i almost hauled it over the scale I was so mad. kind of put it on "time out" so to speak. I did everything on this durango thinking we were gonna have it forever.
The rebuilt engine was one I bought off of CL/ and got conflicting stories about its history when I went after it/ so it gave me doubts, so I was kind of afraid of running it "as was"/ so I wanted to make sure all was good with it, before I stabbed it in. it was just a run of the mill used takeout at that time before I pulled it apart.
I also still have the original engine out of it sitting here, as well, pulled with 258,470 mi. the bottom end was starting to get a little "rattley".
I rebuilt the trans, since I had no history on it and it was "out".
Id been having cat efficiency codes, so it got a brand new cat with the rebuild and new O2 sensors. Because that cat melted down when the rebuild tanked, the current engine in there, got another new cat with the install. Magnaflow "HM series" both times.
I replaced the fuel pump just because.
I rebuilt the front suspension, poly bushings throughout.
I put brand new HD/towing rated leaf springs on it
I sent the injectors in to be rebuilt.
same with the starter and alternator, to the local starter shop.
after it set almost 3 years I happened across another 360 on CL that seemed almost too good to be true and I jumped on it. We're still driving it with that short block and that bad set of EQs that started the mess with the rebuilt engine, on it after paying a machine shop to fix them. I was pissed to have spent money on brand new heads then having to pay again to have them gone thru to make them usable.
The durango sat in the garage for 2-1/2 years as a garage ornament because I was so pissed at it.... the warranty on those heads was 1 yr if I remember right. it wasnt til I bought that 2nd CL engine, and I decided to run it as was (except for new gaskets and freeze plugs) and I took those heads in to be checked when I had them off for new head gaskets, I found out they were cracked, so I pulled the EQs off the rebuilt figuring I could just stab them on this other engine, and I discovered the stuck and bent valves.... I also robbed the new double roller timing chain from the rebuilt engine, its currently on the engine that's now in there.
were still driving that durango, the body just turned 312k miles, its body is still better than many vehicles 10 years newer around here..... the short block in there has about 135k less miles than the body.
other than the EQ heads the only other mod on the engine that's now in there is a set of 1.7 roller rockers I got off a buddy of mine.
I didnt get the 2nd durango I was thinking of building this engine for, the "R/T" turned out to be an SXT witha rotted body out back with a 4.7 in it..... all it cost me was a few hours of windshield time and rental of the tow dolly which I wound up not needing.... were still looking.
I still want to make that doomed rebuild right.... I guarantee I will find something to put it in. so I want to re rebuild it regardless. so Im still gonna scope out this buildup I have in my mind.... maybe I will run across a deal I cant pass up on a set of aluminum heads for it. It seems that eventually things find me "if" and "when" I'm not in a hurry for them. If Im in a hurry cuz I neeed something "now," I wind up gettin screwed.
