Re: disable a modern car but quick fix? [Re: 360view] #3177699
09/24/23 10:06 AM
09/24/23 10:06 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Pull the fuel pump relay, easy to reverse, car won't start but it will crank so they won't think any funny business is up with the keys.
68 Barracuda Formula S 340
Re: disable a modern car but quick fix? [Re: Bad340fish] #3178107
09/25/23 02:15 PM
09/25/23 02:15 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
It will set a code for the fuel pump circuit and he will have to clear it to pass the inspection but when they take it for inspection it will tell them the codes have recently been cleared and will still not pass the inspection, thats why I recomended the starter wire, it won't set a code.
Re: disable a modern car but quick fix? [Re: HotRodDave] #3178223
09/25/23 08:51 PM
09/25/23 08:51 PM
Andrewh Offline OP
Andrewh  Offline OP
is there a starter relay like in mopars? or just small wire to the starter?
Re: disable a modern car but quick fix? [Re: Andrewh] #3178345
09/26/23 12:35 PM
09/26/23 12:35 PM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
little tiny wire just slides over the blade. There is a big fat wire but it is activated by the little one so you only need to slide that one off.
Re: disable a modern car but quick fix? [Re: Dcuda69] #3178451
09/26/23 06:39 PM
09/26/23 06:39 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Originally Posted by Dcuda69
No inertia switch on a 16 Camry. AFAIK Ford is the only passenger car that used them and that was 30 yrs ago.
Crown Vics had them until end of production in 2011 I believe. Nothing much newer has them though- the disablement of the fuel pump after a crash comes from other sources, usually the ABS unit or restraints control module.
Re: disable a modern car but quick fix? [Re: Blusmbl] #3179797
10/01/23 08:00 AM
10/01/23 08:00 AM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
If it's keyless remote entry with a start button as opposed to a standard ignition key, couldn't you just pull the battery out of the key fob? If the car's locked she won't be able to get in unless she pulls the hidden key out of the fob to unlock using the key cylinder on the door. Even if she gets inside, the car won't start. I'm not sure about Toyota, but on Hondas the only way to start the car with keyless and a dead fob is to hold the fob up near the start button while you are pushing the button, so that it can read the fob and determine that the key is present. I suspect they all work basically the same and I don't imagine she would know how to start the car with a dead fob. Might be worth a try.
Feeling for you on the dementia issue. Went through that for many years with the MIL. The car issue worked alright for her as she decided that she shouldn't drive anymore all on her own. She still wanted to be able to see her car every day as she had bought it all on her own and was still very proud of it. So we kept it there for her and she never once attempted to drive it. Best of luck to you. It's a tough situation to be into.
Re: disable a modern car but quick fix? [Re: ChryCoGuy] #3180032
10/01/23 08:57 PM
10/01/23 08:57 PM
PA
70Duster Offline
70Duster  Offline
PA
I just read the whole thread and on the last post ChryCoGuy said exactly what I was going to post. Just take the battery out of both remotes and the problem is easily solved.
Re: disable a modern car but quick fix? [Re: 70Duster] #3196318
12/09/23 06:37 PM
12/09/23 06:37 PM
Andrewh Offline OP
Andrewh  Offline OP
Thought I would follow up.
was able to run a rocker switch hidden under the dash, got a replacement connector and put the switch in line between the original connector and the starter.
works pretty good. has a side affect though.
if you try to "start" with it off, then try to start it with it on, I am guessing the priming squirt still happened. and it will just crank for a long time and then time out and not start.
start it one more time and it will fire up.
but good enough for now.
Thanks for the suggestion.
Re: disable a modern car but quick fix? [Re: Andrewh] #3196621
12/11/23 09:21 AM
12/11/23 09:21 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Bigger issue than the car is why is she home alone? You won’t know how bad off she is getting until it’s too late. Disabling the car can snowball into her walking to wherever and that won’t end well.
I want my fair share
Re: disable a modern car but quick fix? [Re: 360view] #3196638
12/11/23 10:59 AM
12/11/23 10:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by 360view
I have seen this so much.
You have to fight it as best you can, and draw in other family members.
One family friend’s children took his truck away, and he just went down to a dealership and signed the papers to buy a new vehicle for $60,000.
Funny?
It happened twice!
The state took my Dad's driver's license away because he was a hazard on the road. But by God, he was going uptown for the mail. He simply fired up his 9N Ford tractor and drove it to the Post Office. In a rural small town, that didn't even raise an eyebrow.
Re: disable a modern car but quick fix? [Re: Andrewh] #3196641
12/11/23 11:04 AM
12/11/23 11:04 AM
Addison Twp, Mi.
RobG Offline
RobG  Offline
Addison Twp, Mi.
In college, I use to run a poor man's auto theft system - put a toggle switch on the electric fuel pump wire and run it up under the seat or in the center console. When "off" no gas flows - easy to flip on to drive anywhere.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: disable a modern car but quick fix? [Re: 6PakBee] #3196681
12/11/23 01:01 PM
12/11/23 01:01 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Funny?
It happened twice!
LOL. We had a guy local to me that had his license pulled for DUI (WAY too many times). Used to make a trip everyday to the local country bar not too far from my house. Once he lost his license, then out came the Farmall tractor to get to the bar...He did that for a while. Eventually he died which is another interesting story since my buddies were on the township rescue squad.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
