Re: Electronic igniton conversion questions [Re: TJP] #3177118
09/22/23 12:11 AM
09/22/23 12:11 AM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
Hello;
I am planning to do a Mopar Performace style electronic ignition kit for my 66 440 C Body.
Get a good quality ECM from Richard Ehrenberg on E-bay.
Get the MP wiring harness from Mancini Racing or Ehrenberg or others online.
Buy a service part replacement reluctor and pickup plate from any number of sources. Install these in your existing (aluminum) distributor and keep your original advance timing (the MP units were timed for race use anyway).
Installation instructions are all over the web.
Install, and have a good fascmile of the original MP kits, all with readily serviced parts.
Am I missing anything?
Mark
PS, whish this site had spellcheck
Re: Electronic igniton conversion questions [Re: michiganhotrod1] #3177132
09/22/23 07:44 AM
09/22/23 07:44 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Originally Posted by michiganhotrod1
Hello;
Mark
The Rick E-Burg kits on eBay are good kits
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Electronic igniton conversion questions [Re: 340SIX] #3177164
09/22/23 10:42 AM
09/22/23 10:42 AM
5thAve Offline
5thAve  Offline
When I first did my ignition conversion to ditch lean burn I got the parts I needed off a van for $5. I'm still using the Wells ECU that came off it but the distributor was replaced with an MP one ant some point and same with the wiring back when you could still get the conversion harness kit from the dealer for around $20. I originally pieced together the pig tail pieces I cut off the van the rest of the parts came from.
Now I don't even remember when the last time was I saw a vehicle in a junk yard that would have the parts to take!
Re: Electronic igniton conversion questions [Re: 5thAve] #3177248
09/22/23 03:48 PM
09/22/23 03:48 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The OEM Chrysler electronic ignition was phased out and was replaced with the lean burn system. The lean Burn started in 76 or 77 and was pretty much the only choice from about 79 on, until the "new computer system" replaced it.
I suspect 77 or 78 was probably the last factory original electronic ignition systems used, so its not been installed on "new" cars for 45 or so years. Funny thing, the OEM Chrysler electronic ignition system had about a 15 year run as the only factory ignition system since it replaced the points and condenser system, but most of the guys here still are in love with the points, they have not been installed on "new" cars for nearly 60 years.
Re: Electronic igniton conversion questions [Re: gtsdude] #3177590
09/23/23 08:47 PM
09/23/23 08:47 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Originally Posted by gtsdude
FBO still making kits? I have used a couple in the past and they always worked well.
I use the FBO box on my Hemi Charger. Has worked really great, only change from using a Mopar box is the need to jumper out the ballast (I hollowed out a ballast and used a wire soldered in place) and a Pertronix coil which they spec.
No issues, really like it.
Have a bone stock 440 in a 70 Challenger, running the classic Mopar electronic ignition conversion on that. Using the Jegs blue ECU (same that Rick E sells on eBay), has worked great with no issues for several years. I tried it on the Hemi and it worked well, but the FBO box seemed to give me more at all RPM’s (seat of the pants test).
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Electronic igniton conversion questions [Re: Kowal] #3177611
09/23/23 09:52 PM
09/23/23 09:52 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Don't leave the ignition in the on position while testing with the pertronix coils. Had a few blow 💥. Also had a few more just fail. Switched to MSD blaster II's haven't had one comeback yet wink up
