Dual line Milodon oil line routing?
#3176846
09/21/23 07:10 AM
09/21/23 07:10 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have been having priming issues with my dual line system. Takes a lot of drill speed and time to pull oil from pan initially. After sitting for a month, even the 3 qt accumulate prime didn't get it going. My pan to pump hoses were both low from pan to pump. I had to route the front (2nd) line under the pump due to the fuel injection pump being in the way. I checked the pump, and rotor to cover clearance is .004, gears look good, no serious scratches in the cover or pump body. I am going to check on ways to raise both intake lines up, so they can't drain back so easily. Any other thoughts? These are new lines and fittings.
Re: Dual line Milodon oil line routing?
[Re: Stanton]
#3176881
09/21/23 10:25 AM
09/21/23 10:25 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I have a hoop in mine, never any issues. I also have an Accusump which I also use as a primer as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3176925
09/21/23 12:40 PM
09/21/23 12:40 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
I use a dual line setup, my fittings on the pickup point upward. Additionally I have a high in the lines ( think of an upside down P trap to) keep the oil from migrating back to the pan. 70wgt doesn't like to move very fast...especially when temps are in the 60's in the AM. Ill take some pics tonight if you like.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3176927
09/21/23 12:47 PM
09/21/23 12:47 PM
Posts: 22,697 Bitopia
jcc
Bitopia
I don't understand, unless the pump and all upstream is 100% leak proof (by design they can't be), why simple siphon will not over time simply empty the oil lines no matter how they are run, with the pickup always being the lowest point when not using any check valve?
[Re: gregsdart]
#3176940
09/21/23 01:37 PM
09/21/23 01:37 PM
Posts: 3,089 Michigan
A727Tflite
I have been having priming issues with my dual line system. Takes a lot of drill speed and time to pull oil from pan initially. After sitting for a month, even the 3 qt accumulate prime didn't get it going. My pan to pump hoses were both low from pan to pump. I had to route the front (2nd) line under the pump due to the fuel injection pump being in the way. I checked the pump, and rotor to cover clearance is .004, gears look good, no serious scratches in the cover or pump body. I am going to check on ways to raise both intake lines up, so they can't drain back so easily. Any other thoughts? These are new lines and fittings. You are at the maximum clearance suggested by Milodon. They suggest .0015” - .004”. It was proven many years ago that the biggest contributing factor in loss of prime and/or delay to prime is face clearance. Rotor to rotor and outer rotor to bore contribute to this but at a lessor amount.
[Re: gregsdart]
#3177012
09/21/23 06:37 PM
09/21/23 06:37 PM
jcc
Bitopia
Why not be extra safe and just put a full loop in it?
[Re: cudaman1969]
#3177192
09/22/23 12:30 PM
09/22/23 12:30 PM
W.I.N. Racing
Byron, NY
To illustrate the principle
[Re: W.I.N. Racing]
#3177313
09/22/23 08:29 PM
09/22/23 08:29 PM
jcc
Bitopia
perfectly clear. Now explain how that cannot siphon.
[Re: W.I.N. Racing]
#3177358
09/23/23 05:36 AM
09/23/23 05:36 AM
gregsdart
To illustrate the principle This and using oneway check valves per Statons suggestion looks like the most bullet proof deal, as long as those checkvalves flow plenty. The problem is, only double male ended check valves are available for the right flow direction, so s swivel union , female to female, is needed to make it all work.
[Re: gregsdart]
#3177369
09/23/23 07:35 AM
09/23/23 07:35 AM
jcc
Bitopia
Then when using check valve (s), hose routing is still superfluous, unless one empties or inverts the oil pan.
[Re: rickraw]
#3177410
09/23/23 11:27 AM
09/23/23 11:27 AM
6PKRTSE
Motor City
My lines routed. Added heat sleeve due to how close to the headers tubes it gets.
