Re: Warmed over 383 intake and carb questions
[Re: IROC78]
#3177388
09/23/23 09:27 AM
09/23/23 09:27 AM
Posts: 554 Kentucky
clovis
Kentucky
I probably went through 10 carburetors last year. I actually wound up buying a Barry Grant Gold Claw and gathered up all the venturi sleeves, throttle plates and boosters, so I can go from a 750 to 1050 and alter between down leg and annular boosters. I got a lot of information for that setup from reading Brad’s post here and over on Speed Talk, again a lot of good info. I do agree with the statement that you really can’t go by the ratings (750,850, etc) it is venturi, throttle plate and booster. I will say also that an AFR gauge is a really nice tuning aid. I am probably going to bail off and get a second one for the other side on mine. Between time slips, AFR readings and plugs you can get a pretty good handle on what’s going on but to Dwayne’s point, is there 30 hp hiding probably not. For me I do want to get the most of out what I have to a point, but in reality if you are racing, consistency and maintenance are more important.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#3180510
10/03/23 09:52 AM
10/03/23 09:52 AM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
I'm generally in agreement here, I think that manifold is hurting your torque without a significant HP payback up top.
A performer RPM will certainly help your upper bottom and probably work the converter harder throughout the middle, I just don't know if I would prefer it over a mildly ported Street Dominator on your 383 which I think will be just as strong through the middle and (at least from my personal experience) a bit better up top.
The Best thing about a BB Mopar is it's so easy to swap the intakes and compare them literally back to back at the track.
[Re: Streetwize]
#3180959
10/04/23 01:22 PM
10/04/23 01:22 PM
Posts: 19,687 north of coder
moparx
i used a DP4B intake, 850 Thermo-Quad, SSH-25 cam on an otherwise stock 383. 2500 converter and 3.91's in my charger. that combo worked pretty good for what it was. best et was 13.56 [i can't remember the mph] but usually ran 13.79-13.90, without getting into the distributor to get a good curve. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
