Re: Fuel Line Size [Re: jlatessa] #3177334
09/22/23 11:35 PM
09/22/23 11:35 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted by jlatessa
B1MAXX...calipered the I.D.?
Joe
OD. thats the hose size id.
Re: Fuel Line Size [Re: B1MAXX] #3177385
09/23/23 09:12 AM
09/23/23 09:12 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I replaced my old lines when I restored the car but I still have the 3/8 line and sending unit. I don't know why but I kept all the old parts I could.
1969 Hemi Roadrunner 2nd owner
Re: Fuel Line Size [Re: 69hemibeep] #3177391
09/23/23 09:46 AM
09/23/23 09:46 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
B1MAXX, you are correct, learned something today.
So we're better off with a 3/8" flex fuel hose with a larger I.D.??
Joe
Re: Fuel Line Size [Re: jlatessa] #3177393
09/23/23 09:57 AM
09/23/23 09:57 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have 4 or 5 old original pumps, I know one is off a 68 GTX, all are 5/16” non Carter pumps.
Re: Fuel Line Size [Re: jlatessa] #3177558
09/23/23 07:29 PM
09/23/23 07:29 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Joe
possibly, but in my experience the pumps were the limiting factor from the factory with 3/8 steel line, except maybe the hemi pump...I never had one of those. My stock 440 pump would cut in and out under full throttle bonzai blasts.
Re: Fuel Line Size [Re: dragon slayer] #3178978
09/28/23 01:10 PM
09/28/23 01:10 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
After finding my original fuel line from my car, I found that it is 5/16. I also measured the original fuel line on my 70 hemi charger and it is 5/16 also. I personally think that both sizes were used depending possibly on what was available at the time.
Re: Fuel Line Size [Re: 3_RTs] #3178986
09/28/23 01:57 PM
09/28/23 01:57 PM
The outside diameter of the stock fuel lines are not what the insides are, a 5/16 O.D. may be less than .300 I.D., less around corners shock work
I try and use a 1/2 O.D. thin wall steel tube for my half way serious race cars, a lot larger than needed is way better than a tiny bit to small twocents work
If I can't fatten the mixture up enough to slow the MPG down in the 1/4 mile I don't have enough fuel delivery shruggy work wrench
My new heads up no prep car will have #12 AN from the fuel tank to the crank driven mechanical race pump on the front of the gear drive for the centrifugal superchargers and other accessory needed to be completive wrench up
Re: Fuel Line Size [Re: 3_RTs] #3179203
09/29/23 07:29 AM
09/29/23 07:29 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I don't buy this one bit. Maybe the 69.but not the 70.
I should clarify.... in regard to the tank to pump.
