Re: disable a modern car but quick fix?
[Re: 360view]
#3177699
09/24/23 10:06 AM
09/24/23 10:06 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
Pull the fuel pump relay, easy to reverse, car won't start but it will crank so they won't think any funny business is up with the keys.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3178107
09/25/23 02:15 PM
09/25/23 02:15 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Pull the fuel pump relay, easy to reverse, car won't start but it will crank so they won't think any funny business is up with the keys. It will set a code for the fuel pump circuit and he will have to clear it to pass the inspection but when they take it for inspection it will tell them the codes have recently been cleared and will still not pass the inspection, thats why I recomended the starter wire, it won't set a code.
[Re: Andrewh]
#3178345
09/26/23 12:35 PM
09/26/23 12:35 PM
HotRodDave
Kalispell Mt.
little tiny wire just slides over the blade. There is a big fat wire but it is activated by the little one so you only need to slide that one off.
[Re: Dcuda69]
#3178451
09/26/23 06:39 PM
09/26/23 06:39 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
No inertia switch on a 16 Camry. AFAIK Ford is the only passenger car that used them and that was 30 yrs ago. Crown Vics had them until end of production in 2011 I believe. Nothing much newer has them though- the disablement of the fuel pump after a crash comes from other sources, usually the ABS unit or restraints control module.
[Re: Blusmbl]
#3179797
10/01/23 08:00 AM
10/01/23 08:00 AM
Posts: 6,321 o
ChryCoGuy
o
If it's keyless remote entry with a start button as opposed to a standard ignition key, couldn't you just pull the battery out of the key fob? If the car's locked she won't be able to get in unless she pulls the hidden key out of the fob to unlock using the key cylinder on the door. Even if she gets inside, the car won't start. I'm not sure about Toyota, but on Hondas the only way to start the car with keyless and a dead fob is to hold the fob up near the start button while you are pushing the button, so that it can read the fob and determine that the key is present. I suspect they all work basically the same and I don't imagine she would know how to start the car with a dead fob. Might be worth a try.
Feeling for you on the dementia issue. Went through that for many years with the MIL. The car issue worked alright for her as she decided that she shouldn't drive anymore all on her own. She still wanted to be able to see her car every day as she had bought it all on her own and was still very proud of it. So we kept it there for her and she never once attempted to drive it. Best of luck to you. It's a tough situation to be into.
[Re: Andrewh]
#3196621
12/11/23 09:21 AM
12/11/23 09:21 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
Bigger issue than the car is why is she home alone? You won’t know how bad off she is getting until it’s too late. Disabling the car can snowball into her walking to wherever and that won’t end well.
I want my fair share
[Re: 360view]
#3196638
12/11/23 10:59 AM
12/11/23 10:59 AM
Posts: 10,756 North Dakota
6PakBee
North Dakota
I have seen this so much.
You have to fight it as best you can, and draw in other family members.
One family friend’s children took his truck away, and he just went down to a dealership and signed the papers to buy a new vehicle for $60,000.
Funny?
It happened twice! The state took my Dad's driver's license away because he was a hazard on the road. But by God, he was going uptown for the mail. He simply fired up his 9N Ford tractor and drove it to the Post Office. In a rural small town, that didn't even raise an eyebrow.
[Re: Andrewh]
#3196641
12/11/23 11:04 AM
12/11/23 11:04 AM
Posts: 2,334 Addison Twp, Mi.
RobG
Addison Twp, Mi.
In college, I use to run a poor man's auto theft system - put a toggle switch on the electric fuel pump wire and run it up under the seat or in the center console. When "off" no gas flows - easy to flip on to drive anywhere.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
[Re: 6PakBee]
#3196681
12/11/23 01:01 PM
12/11/23 01:01 PM
Posts: 5,479 Michigan
oldjonny
Don't argue with me.
Funny?
It happened twice! The state took my Dad's driver's license away because he was a hazard on the road. But by God, he was going uptown for the mail. He simply fired up his 9N Ford tractor and drove it to the Post Office. In a rural small town, that didn't even raise an eyebrow. LOL. We had a guy local to me that had his license pulled for DUI (WAY too many times). Used to make a trip everyday to the local country bar not too far from my house. Once he lost his license, then out came the Farmall tractor to get to the bar...He did that for a while. Eventually he died which is another interesting story since my buddies were on the township rescue squad.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
