Re: trick flow 240 cyl head question.
[Re: sr4440]
#3253091
08/22/24 12:08 PM
08/22/24 12:08 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What does the converter flash to on the line now?
Did you mill the new heads before installation? New CR?
[Re: fast68plymouth]
#3253141
08/22/24 03:24 PM
08/22/24 03:24 PM
Posts: 124 pa
gregcharger72
pa
Did you mill the new heads before installation? New CR? 5300 , The flash speed didn't really change, about 100 rpm more over the 240 heads according to my playback tach. No , I did not have the heads milled.
[Re: AndyF]
#3253149
08/22/24 05:51 PM
08/22/24 05:51 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
My Satellite 60's similar to yours . 1.48-50 average . Off the footbrake low rpm . Goes .44-47 off transbrake . I also feel its a bit soft but havent really worked out why . I know with 30"radial it probably wants 4.3 gears rather than 4.1 . Not happening . Mine is on the heavier side . I know/feel with the 10.30s footbraking it should go lower 40s .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: AndyF]
#3253220
08/22/24 10:30 PM
08/22/24 10:30 PM
Posts: 124 pa
gregcharger72
pa
What is the combination that you have now? How much power do you think the engine is making in the car? The combination is a .030 440 with 270 heads , A trick flow max wedge intake, a 4150 series 1000cfm carb, the cam is a Hughes engines 260/264 @ .050 cam with 1.6 rockers , 2" headers , 3" exhaust system. The car has 4.30 gear , 9x30 tires, a dynamic brand 9 " converter that flashes 5200-5300 range . Car weighs 3655 with me in it. Using the Wallace calculator the engine is in the 625 hp range . The 270 heads picked up about 3.5 mph over the 240 heads , same track with similar weather conditions.
[Re: sr4440]
#3253224
08/22/24 10:47 PM
08/22/24 10:47 PM
Posts: 124 pa
gregcharger72
pa
Can you post a pic of your plugs? Because if you increase the airflow into the engine and didn't pull a little timing, you may be over center.
Joe I did a timing sweep and the best mph is 34* total. I used a wide band for a/f ratio tuning. The engine likes 13.1-13.4 at WOT when I jet up into the 12.8 -12.9 range the car slows up.
[Re: HardcoreB]
#3253280
08/23/24 07:41 AM
08/23/24 07:41 AM
Posts: 8,225 Plymouth, MI
Blusmbl
Plymouth, MI
Based on mph alone, at 3600# you picked up ~55 hp with the head swap. At 0.600" and 0.700" lift the 270's are about 20 cfm better than the 240's, and at 2 hp per cfm you definitely got the HP improvement from the heads. Agree that maybe exhaust or a different induction setup migght get you another tenth or so. If it's full 3" exhaust it's probably a choke point and worth trying cutouts. Again, absolutely beautiful Charger!!
[Re: Blusmbl]
#3253286
08/23/24 08:50 AM
08/23/24 08:50 AM
Posts: 124 pa
gregcharger72
pa
The cam is a flat tappet , I talked with two engine builders about a roller cam, both discouraged the swap, I was told there would not be to be a significant change in hp in relationship to the cost of a roller setup. The cylinder heads have been a definite improvement. I'm starting to realize that making a big car fast is not going to easy or cheap. LOL my next step is going to be to take exhaust off the car for my next trip to the track. And see what happens. I bought 18" collector extensions to put on and try.
[Re: gregcharger72]
#3253352
08/23/24 02:24 PM
08/23/24 02:24 PM
Posts: 43,744 Bend,OR USA
Cab_Burge
My old pump gas street Duster would loose .0003 to .0005 E.T. and .2 MPH with the full 3.0 inch exhaust system on that car, I think the differences was the lighter weight, the muffs were mounted behind the rear end between the 1/4 panels and stock rear sub frames, the head pipes ran under the rear end housing directly from the Hooker A body B engine headers were fender well exit with 1 7/8 primary pipes and 3.5 inch collector- Be careful when testing the new combo please
[Re: Cab_Burge]
#3253376
08/23/24 05:14 PM
08/23/24 05:14 PM
Posts: 146 NJ
cb1289
NJ
Beautiful car. good move with the exhaust. If you can , my 2 cents for what its worth is loosen the converter. If you want to spend money try 2.77;1 low gear. 3700 lbs will like it by a tenth if you can hook it up
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: cb1289]
#3253421
08/23/24 09:37 PM
08/23/24 09:37 PM
Posts: 5,173 CT
GTX MATT
CT
I think the easiest change that will yield you power is to try a Dominator
[Re: GTX MATT]
#3253811
08/26/24 09:04 AM
08/26/24 09:04 AM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Might be time to switch to an 8" Converter and as others have said the Solid Cam is maybe a little small, and you'd probably benefit from a bit more lift.
TBH I'm happily surprised for you that the heads are picking you up as much as they are.... with 'only' 440 cubes. Have your shift points changed?
To work the 270's you may need at least a couple 100 more rpm.
Does your charger have a spoiler on the front? B bodies pick up a lot of air underneath so they might help your top end MPH.
[Re: GTX MATT]
#3253865
08/26/24 01:24 PM
08/26/24 01:24 PM
Posts: 3,371 Md.
carnut68
Md.
I think the easiest change that will yield you power is to try a Dominator This. I picked up 2 tnths on stock stroke 440. Thumper 1050.
America First!
