Cell phone reception #3175829
09/17/23 01:56 PM
09/17/23 01:56 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I have a metal clad pole building and once inside the reception goes away to where I have to l go outside to get internet service. Calls sometime come thru as does text but not often. I’m in a rural area so it’s not all that great anytime. Any suggestions on getting a signal in the building?
Re: Cell phone reception [Re: cudaman1969] #3175833
09/17/23 02:20 PM
09/17/23 02:20 PM
BDW Offline
BDW  Offline
Cell repeater, search Amazon
Re: Cell phone reception [Re: BDW] #3175845
09/17/23 03:12 PM
09/17/23 03:12 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Boosters work well also.
Re: Cell phone reception [Re: moparjim79] #3175935
09/17/23 10:34 PM
09/17/23 10:34 PM
Milford, OH
markz528 Offline
markz528  Offline
Milford, OH
Do you have WIFI in the shop? If so, us WIFI calling. That is what I do. I get no cell reception through the metal siding. I just use WIFI calling and it does not skip a beat.
67 Coronet 500 (street car) 13.300 @ 101.75 mph
Re: Cell phone reception [Re: markz528] #3175944
09/18/23 12:48 AM
09/18/23 12:48 AM
What is WIFI calling .
What exactly, parts, are needed to make that work help up
Re: Cell phone reception [Re: Cab_Burge] #3175947
09/18/23 01:54 AM
09/18/23 01:54 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Years ago on an older phone I used google voice, it only worked when connected to a wi-fi network. I had a private wi-fi network setup at work as well as home. Had I set up a wireless network in the car, it would have worked there as well.
As I understand it, when using a cellular network, if you've turned wi-fi on in your phone, whenever you're connected to a wi-fi network, it'll use the wi-fi network in lieu of your cellular network. If you're streaming video or music ( I don't ) it'll save you lots of data usage.
Here's a short video explaining how to turn it on.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Cell phone reception [Re: 3hundred] #3176070
09/18/23 03:07 PM
09/18/23 03:07 PM
fredericksburg,va
fredericksburg,va
I’ll try that but there’s only cable for internet here, broadband has been looked into but not yet. If I sound dumb on this stuff it’s because I am lol.
Re: Cell phone reception [Re: cudaman1969] #3176074
09/18/23 03:28 PM
09/18/23 03:28 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Check with your internet provider to see if your cable modem has wifi. If not, you can add a wireless router and you'll be able to connect that way.
'69 300 Convertible
'16 300 S Hemi
Re: Cell phone reception [Re: 3hundred] #3176180
09/18/23 09:38 PM
09/18/23 09:38 PM
fredericksburg,va
fredericksburg,va
I tried the wifi thing and still no bars.
Re: Cell phone reception [Re: cudaman1969] #3176215
09/18/23 11:56 PM
09/18/23 11:56 PM
Milford, OH
markz528 Offline
markz528  Offline
Milford, OH
You don’t get bars with WIFI calling. You must have a WiFi signal and the phone enabled for WiFi calling. Then you can use the phone for calling.
In my house I get 0-1 bars. Many times not enough for it to work. I put the phone in airplane mode and just use WiFi calling. Works great. Get 0 bars in my metal sided shop.
