Sheet metal tunnel ram #317604
05/14/09 12:15 AM
05/14/09 12:15 AM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Hey Guys
My cousin just finished my sheet metal tunnel ram for the Henry J, not too bad for basically his first attempt at making one eh He says he might be interested in making more so if you are interested let me know and I can put you in contact with him. I am sure they will be much cheaper that others of same quality
Derrick
Re: Sheet metal tunnel ram [Re: Hyper Henry] #317605
05/14/09 04:40 AM
05/14/09 04:40 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what kinda $$ are we talking about for a B engine? ballpark is fine.
Re: Sheet metal tunnel ram [Re: rebel] #317606
05/14/09 06:24 AM
05/14/09 06:24 AM
La Grange, Ky
70rrclone Offline
70rrclone  Offline
La Grange, Ky
and rb too
shane
Post deleted by Defbob [Re: Hyper Henry] #317607
05/14/09 06:37 AM
05/14/09 06:37 AM
Re: Sheet metal tunnel ram #317608
05/14/09 06:42 AM
05/14/09 06:42 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
When is the Henry going to be hitting the track again? It looks like its close to being ready.
Re: Sheet metal tunnel ram [Re: Hyper Henry] #317609
05/14/09 07:52 AM
05/14/09 07:52 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Lets see a picture of the inside
Re: Sheet metal tunnel ram #317610
05/14/09 08:13 AM
05/14/09 08:13 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
is that done with one of those kits ? who designed it ?
Exactly. There is more to fabbing a manifold than welding sheet metal together. Keep us informed how this manifold compares to your previous one.
Re: Sheet metal tunnel ram [Re: BobR] #317611
05/14/09 05:18 PM
05/14/09 05:18 PM
Ontario, Canada
Ontario, Canada
Intake specs were done by Damon kuhn (aka Fugly) and built by my cousin Dean. Dean use to have his own fabricating shop but got out of it because of too much overhead. Now he just does small jobs out of his garage and he's much happer Damon wanted every spec on my motor so it's a custom build, no kits here I will let you know how it works in a couple weeks. Yep the Henry J is just about ready to hit the track again I had a lazy winter so behind schedule
Derrick
Re: Sheet metal tunnel ram [Re: Hyper Henry] #317612
05/14/09 05:20 PM
05/14/09 05:20 PM
Ontario, Canada
Ontario, Canada
another pic
Re: Sheet metal tunnel ram [Re: Hyper Henry] #317613
05/14/09 08:58 PM
05/14/09 08:58 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Derrick
Would that be GREEN Dean??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Sheet metal tunnel ram [Re: hemi-itis] #317614
05/14/09 09:42 PM
05/14/09 09:42 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i can tell you that won't work. it's not made by one of those big name, take all of your money, overpriced companies. the bottom line is, you don't have to.... ah, never mind. it looks great
Re: Sheet metal tunnel ram [Re: tjmarcus1] #317615
05/14/09 09:51 PM
05/14/09 09:51 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I was thinking the runner entrances needed a radius put on them to help the flow into the runner. I'm not a head porter or intake builder though. I'd try it the way it is and later pull the top to see if the intake gives any clues as to how to improve it. I bought a Weiand 6-Pack cross/tunnel ram with the popsickle sticks and I could see where raw fuel ran all over the top from the fuel separating out below the carbs. It may not be as obvious on this intake as it was on the Weiand.
Floyd Lippencott IV
Re: Sheet metal tunnel ram [Re: Hyper Henry] #317616
05/14/09 10:04 PM
05/14/09 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good. I turned my carbs on the one I built(the
last one I built) so that each barrel of the carb is
over a runner(turned about 15*). I hope it works well
for you... he did a nice job
Re: Sheet metal tunnel ram [Re: mr_340] #317617
05/14/09 10:12 PM
05/14/09 10:12 PM
Hell Ya, First post and in my cousins thread no less.lol.
I hope it works well for Derrick, With Fugly's specs and MoPar power Im sure it will rock the house.
Me and Derrick talked about it might be good idea to put a radius on the runner entrance in the the plenum. It could help the air speed and reduce some turbulance. If the intake shows some raw fuel on the floor then I will radius the runners. I didnt have much radius on the one I had built for my 493 Challenger and had no signs of fuel problems. Try it and see what happens. Its easy to yank. And thanks for the props guys.
Re: Sheet metal tunnel ram [Re: MR_P_BODY] #317618
05/14/09 10:21 PM
05/14/09 10:21 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Quick question, Why couldnt you make on out of tin? Use a 1/4 plate for the flange and just weld tubing to it to the top and make a base for the carbs, I know wieght is probly the biggest reason not to but seems like it would work the same.... ...It would still be lighter then a stock intake though....Phill
Re: Sheet metal tunnel ram [Re: 9 Sec Phill] #317619
05/14/09 10:27 PM
05/14/09 10:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing is that the runners have a taper to them to
get the velocity up. I would rather work with alum
than steel due to worpage... plus the weight thing
Re: Sheet metal tunnel ram [Re: MR_P_BODY] #317620
05/14/09 10:30 PM
05/14/09 10:30 PM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I could see myself making an intake for a set of W2's using some exhaust pipe and a upside down mailbox.....I think I could make the intake look better then the one on the high and mighty, maybe even twist the tubes for a faaster air flow or charge to the heads...Phill
Re: Sheet metal tunnel ram [Re: 9 Sec Phill] #317621
05/14/09 10:42 PM
05/14/09 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I did some work on that "High and Mighty" car, that
intake was the goofiest looking thing I have ever
seen,
but it was simple and quick to build/test. Its easier
to shape the alum than it is steel tubing... but I
have made some intakes out of steel... it worked
ok but its easier with the alum... JMO
Re: Sheet metal tunnel ram [Re: MR_P_BODY] #317622
05/15/09 11:00 AM
05/15/09 11:00 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Kool cant wait for testing. then I need a job and get mean Dean to make me one?? A 542 and one of those could be my Xmas present to myself.
Dam I found a set of wickies used pistons in the garage that don't look to bad that should be 4.5 stroke 4.38 bore and work with the 6.856 aluminum rods I have??
Also found a set for 4.25 stroke but they are 4.5 bore!
Re: Sheet metal tunnel ram [Re: Dodgem] #317623
05/17/09 02:25 PM
05/17/09 02:25 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Anyone have a pic of the inside of a Hogans Tunnel ram or another big name company???
Re: Sheet metal tunnel ram [Re: Diablo] #317624
05/17/09 05:03 PM
05/17/09 05:03 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
That intake looks great!!
You gonna be at the OSCA race next weekend? You can run in Pro comp.
87 dakota 6.1 hemi
Re: Sheet metal tunnel ram [Re: Diablo] #317625
05/17/09 05:37 PM
05/17/09 05:37 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
My CFE Sheet Metal intake with a single 4brl
AL...
Alan Jones
Re: Sheet metal tunnel ram #317626
05/17/09 07:40 PM
05/17/09 07:40 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
sure, a little bit of a radius would be nice, but, as all can see, it's a simple fix. my hat is off. good job.
