Page 3 of 3 1 2 3
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: 70blackfish] #31757
05/30/08 09:32 PM
05/30/08 09:32 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
in some rebuild kits there is a piece of fiber that goes in front of oil slinger, I had that come off and somwhat plug my oil pick up tube/
The fiber ring that I recall in the kits goes in the damper, outside of the front cover. I've never seen one put inside the front cover.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Evil Spirit] #31758
05/31/08 09:51 AM
05/31/08 09:51 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
i had a small block in my bracket car that did the same thing (318 or 360 i can't remember). i checked alot of things but never did find anything to blame it on. 1 old timer told me he had a ford motor do the same thing and after 3 rebuilds he discovered a crack in the lifter galley which would open some and bleed off presure with engine heat. of course there is no way to fix that so i would run the motor as is and start gathering parts for a backup motor if this 1 goes belly-up 3ddart
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: 3ddart] #31759
05/31/08 01:01 PM
05/31/08 01:01 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have been pounding an LA motor for about four months almost daily (4.10's, 4-speed). It has about 20 psi at idle normal operating temp but goes to 15-17 when it gets over 200 F. At 6500 it is pumping ~65-70 psi. So far so good.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31760
05/31/08 03:23 PM
05/31/08 03:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What oil filter are you using?
maybe somewhat related.
he's ran a wix/napa gold forever, the last time he changed it was on a sunday and the local napa was closed so he just grabbed a bosch. There is a bosch currently on there..
Is this a test? The answer is; the piece of crap middle short one is the fram.
Don't even use them on your lawnmower.
I would not worry about the oil preasure you have.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: HotRodDave] #31761
05/31/08 05:01 PM
05/31/08 05:01 PM
USA
V
VS29H0B Offline
VS29H0B  Offline
V
USA
My 1969 340 Swinger, that I sold in 2001, had low oil pressure at idle, when the car was fully warmed up. Most of the time I had 10-12 lbs. at 750RPM idle, fully warmed up. One time the car was idling at 650, and the mechanical gauge read 8 lbs.!
The red oil pressure warning lamp faintly lit, but I jacked the idle to 950 and the lamp never lit again.
One area I was told to check but never got around
to was the pump pickup clearances, to the depth to the bottom of the pan, the angle of the tube, and the mating surface at the attachment point.
Engine never ticked, and the oil pressure increased as early posters stated, in a linear fashion to 50/60 lb.s at 60 MPH cruise.
The engine ran like that for 2 years, and I put a couple thousand miles on that engine, ran like a scalded dog!
The new owner also never had a problem, and he subsequently sold the car, and now ... still no problem!
Drive it and don't worry!
Like the women I have dated --- Always looking for a better deal ....
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31762
06/02/08 10:37 PM
06/02/08 10:37 PM
Northern Ontario
Hans Offline
Hans  Offline
Northern Ontario
I had a built 340 in the Cuda and it had the same pressure that you described. Ran it for a lot of years and no problems. Now I have a built 408 in it with a HV pump...same oil pressure. I've ran this setup for a few years now and no problems. You have 10k miles on it now...don't worry about it.
Page 3 of 3 1 2 3
