1970 challenger wiring #3174789
09/12/23 07:41 PM
09/12/23 07:41 PM
O
otter440 Offline OP
otter440  Offline OP
O
i am doing 1970 challenger went with all new wiring in the car i have pretty much evrything working but the dash lights and headlamps. i have tried different h/l switches. dash dimmer switch, and floor dimmer switch. for some reason i have no power to the orange wires in the dash and no headlamps. the marker lights,taillights and parklamps all work fuse is good. I am baffled any suggestions thanks
Re: 1970 challenger wiring [Re: otter440] #3174795
09/12/23 07:55 PM
09/12/23 07:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are your grounds all good? You Should have power to one terminal on the high low floor switch with the headlights on. with the HL switch plugged in but not installed you should be able to see which terminals supply 12v out. Dash lights have their own fuse fed by the dimmer.
Re: 1970 challenger wiring [Re: stumpy] #3174802
09/12/23 08:11 PM
09/12/23 08:11 PM
O
otter440 Offline OP
otter440  Offline OP
O
my grounds are good. i have no power to the fuse for the dash lights
Re: 1970 challenger wiring [Re: otter440] #3174833
09/12/23 10:07 PM
09/12/23 10:07 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
have you checked the thumbwheel dimmer for the dash lights. If at either extreme it could shut beer the power off
Re: 1970 challenger wiring [Re: TJP] #3174879
09/13/23 08:52 AM
09/13/23 08:52 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Just to clarify, you have no power to the circled orange connector?
Re: 1970 challenger wiring [Re: EW1BH27] #3174884
09/13/23 09:12 AM
09/13/23 09:12 AM
O
otter440 Offline OP
otter440  Offline OP
O
That is correct
Re: 1970 challenger wiring [Re: otter440] #3174889
09/13/23 09:39 AM
09/13/23 09:39 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I don't have a '70 available but looking at the wiring diagram for a '71 it seems straightforward. Black wire from the headlight switch to the dimmer switch. Tan wire from the dimmer switch to the fuse block. Fuse. Orange wires to dash lights. Follow the trail. Good luck.
Re: 1970 challenger wiring [Re: otter440] #3174912
09/13/23 12:23 PM
09/13/23 12:23 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
While the diagram that EW1BH27 posted is helpful, you really need the schematic for the entire car or at least those showing the dashboard/dimmer switch forward. You can try to get by with out it but it really saves time>
the entire service manual is available here for FREE FREE Manuals
I print out the sections needed, tape them together if necessary, and strongly encourage a box of assorted colored pencils to trace the wires.
I would go after each circuit separately Starting with the headlights. It may take a little bit to familiarize yourself with the way the schematic(s) were done but it is pretty easy. Optionally buy one of the laminated full size color coded schematics.
1. Do you have power at the center terminal of the dimmer switch? that power comes from the headlight switch. No power? check the other two terminals just for giggles. I've seen several mis-wires on "NEW" harnesses as well as bad crimps.
a). Check the headlight switch to verify power is present at the terminal that feeds the H/L's when they are on. Be aware some cars use separate 12v feeds for the H/L's and other lights. the largest wire is normally headlights.
b) If you don't have power at the output to the dimmer, using a wiring diagram for YOUR car work your way back to find the source of that power. If there are connectors along the way, checking each connector and the in and out terminals.
keep us posted beer
Re: 1970 challenger wiring [Re: TJP] #3174931
09/13/23 01:25 PM
09/13/23 01:25 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Here's the other 1/2 of my posted schematic
Re: 1970 challenger wiring [Re: EW1BH27] #3174949
09/13/23 02:39 PM
09/13/23 02:39 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Orange wire is powered through the ignition switch, may want to try jumping the wires there.
Re: 1970 challenger wiring [Re: spk2go] #3175051
09/13/23 09:43 PM
09/13/23 09:43 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
That would have nothing to do with the power for the head or dash lights. it may be an indicator lamp for the ignition switch
Re: 1970 challenger wiring [Re: TJP] #3185877
10/23/23 11:03 AM
10/23/23 11:03 AM
NY
firebreather Offline
NY
keep us posted beer
Thank you, I will download these manuals. I have no power to either the headlights or the marker lights, I'm trying to figure it out.
Re: 1970 challenger wiring [Re: firebreather] #3185886
10/23/23 11:35 AM
10/23/23 11:35 AM
IMGTX Offline
IMGTX  Offline
When Checking for Voltage at the plug do not use a VOM connected to both sides of the plug. Run one lead of the VOM to the battery.
You could have a bad ground which looks like no voltage at the plug, very common. If you ground the VOM at the battery when you check for Positive voltage at the plug you will get an accurate reading as to whether or not there is Positive voltage at the plug.
I always confirm my ground to my test gauge/light is good before I test for voltage.
Hope it helps.
Re: 1970 challenger wiring [Re: 6PakBee] #3185930
10/23/23 01:39 PM
10/23/23 01:39 PM
I think that Dodge change some of the wring harnesses on both E bodies from 1970 to 1971 and later, maybe not scope twocents
