Re: wiring/terminals Q [Re: Al_Alguire] #3172563
09/03/23 12:22 PM
09/03/23 12:22 PM
RapidRobert Offline OP
there was info about using something on the connection before you slide the heat sink sleeve over it (dielectric grease?)
Re: wiring/terminals Q [Re: RapidRobert] #3172574
09/03/23 01:02 PM
09/03/23 01:02 PM
moparx Offline
moparx  Offline
i wouldn't bother with the grease.
just use the marine grade tubing with the sealing glue.
beer
Re: wiring/terminals Q [Re: moparx] #3172588
09/03/23 02:21 PM
09/03/23 02:21 PM
OK, does the marine grade tubing come with the sealing glue or is that a separate purchase? if so what/where to get it?
Re: wiring/terminals Q [Re: RapidRobert] #3172832
09/04/23 01:56 PM
09/04/23 01:56 PM
moparx Offline
moparx  Offline
the marine grade tubing has the glue inside the tubing.
the heat used to shrink the tubing activates the sealing glue. nothing else to buy.
https://www.amazon.com/Wirefy-275-Heat-Shrink-Tubing/dp/B084GWYX42/ref=sr_1_3?
beer
Re: wiring/terminals Q [Re: markz528] #3172859
09/04/23 03:37 PM
09/04/23 03:37 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Originally Posted by markz528
Biggest problem is cracking. The solder does not do well in vibration environments and a car is a vibration environment.
x2. The wiring will typically crack where the solder ends, we have seen it over and over on durability routes. From what I understand, connections aren't supposed to be soldered on airplanes for the same reason.
Re: wiring/terminals Q [Re: Blusmbl] #3172885
09/04/23 04:46 PM
09/04/23 04:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I must take longer than 30 years because my crimped and soldered connections that I made are still good. I think as long as you keep your wires from vibrations and run it in insulated clamps like I do there won't be an issue. I use crimp terminals for interior wiring or connections that aren't exposed to the weather. After 40 years as an Import technician I have seen my share of corroded crimped connectors here in the rust belt.
Gus beer
64 Plymouth Savoy
Dana 60
Re: wiring/terminals Q [Re: fourgearsavoy] #3172910
09/04/23 05:51 PM
09/04/23 05:51 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Re: wiring/terminals Q [Re: CMcAllister] #3172917
09/04/23 06:26 PM
09/04/23 06:26 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
The trick I use to protect solder joints is strain relief . I will put 2 sometimes 3 shrink tubes . Each one longer than the previous and always long to protect the solder so the wire doesn’t flex in that area . Also if it makes sense use as little solder as possible to keep the wicking up the wire to a minimum
....BAD A$$ STREET CAR.....
Re: wiring/terminals Q [Re: fourgearsavoy] #3173014
09/05/23 02:19 AM
09/05/23 02:19 AM
Gus beer
I started working for a small telephone company in 1964, the cable splicers would skin and twist the smaller gauge wires and insulate them with small paper or plastic sleeves depending on what the cables were insulated with originally. They used insulators over the 20 GA or smaller cable wires when splicing the telephone cables together, they would twist and solder the 19 GA cables and slide the insulators over them. It didn't matter if the cables were on poles or in conduits underground, they used the same techniques on both shruggy
I don't have a clue what they do now in this age of smart phones whistling grin
