Page 2 of 3 1 2 3
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31737
10/22/06 10:20 PM
10/22/06 10:20 PM
"Bosch
This is yet another Champion Labs filter that is sold at AutoZone. I am not a big fan of Champion filters. They seem flimsy on the inside to me."
http://minimopar.knizefamily.net/oilfilters.html
Re: Friends 'low' oil psi 340, only about 10,000miles #31738
10/22/06 10:41 PM
10/22/06 10:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
To answer your question about cutting the filter open: cut the can off and away, pull out the filter and lay it out where you can look at it. Good lighting is important, to see the reflection of metal particles. Look at the whole filter inside as you take it apart, checking for collapse, etc like in the photos above.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31739
10/22/06 10:54 PM
10/22/06 10:54 PM
I'd heard that about alot of the newer oils especially with solid cams, I've always used valvoline Durablend and I've had no issues
Re: Friends 'low' oil psi 340, only about 10,000miles #31740
10/23/06 12:05 PM
10/23/06 12:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not to hijack, but what filter is the best to use? Mike
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31741
10/23/06 12:27 PM
10/23/06 12:27 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
hot cruise is about 40 (~3,000rpm) and might get up to 50 if he runs it through the gears.
10PSI per thousand rpm is fine. but even on a street car, this is not enough for me. I hit 5K in my dump run pickup with my stock 400 on highway on ramps. Change the oil and filter first, get a hand help diagnostic gage too. If it changes at all in the wrong direction, I wouldnt hesitate to pull it.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: moper] #31742
10/23/06 02:52 PM
10/23/06 02:52 PM
P
Paul_Fancsali Offline
P
The key here is it making noise or blowing smoke?I would frankly leave it alone nothing wrong with the lower pressure.Years ago I thought I needed more oil pressue too well I ended up with 110 lbs!!! Now unless you are running a all out racing engine 40-60 at cruise and low as 10 are perfectly OK. Around 14 years ago I had to call Chrysler engine hot line about low oil pressure for a 3.0. The first thing said was did it have at least 4 psi at idle No I said it had 7 I was told do nothing as there was nothing wrong with it In retrospect The car continued running with the low pressure for years body went away and car was finally junked witha bad trans
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Paul_Fancsali] #31743
10/23/06 03:03 PM
10/23/06 03:03 PM
dogdays Offline
dogdays  Offline
I don't always agree with Paul but I do here. There is no reason to get more oil pressure unless you WANT to eat more horsepower in the oil pump. Or, throw in one can of STP to thicken it up a bit.
R.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: dogdays] #31744
10/23/06 07:55 PM
10/23/06 07:55 PM
georgia
darenrt Offline
darenrt  Offline
georgia
I have read where Lucas can cause the oil to foam in the crankcase.
air does not make a good lube.
experiments can be seen at bobtheoilguy.com also claims Fram filters are junk. I lost 8-10lbs. using a Fram.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: topside] #31745
01/06/07 11:42 AM
01/06/07 11:42 AM
Oklahoma
Mopar72Man Offline OP
Oklahoma
Issue still remains, in re-reading this reply.
First thing I'd do is try another gauge; then cut the oil filter open and inspect the element for bearing material.
Could be bearing clearances too large, oil being aerated, maybe the filter going into bypass. Sounds like the oil has to be cold (thicker) or the pump spun up to maintain oil pressure, which sounds like an internal (pressure) leak. It doesn't sound fatal, but it doesn't sound right, either; mine have always idled hot with at least 30PSI with a stock pump and regardless of mileage.
i'm wondering why if when the motor was first fired. At idle it held about 30lbs hot. Not its dwindled down to 15.
Any other suggestions? Could a faulty pump/spring be the culprit? He has a oil idiot light for 15psi and a autometer gauge. light comes on and the gauge shows 15 at hot idle. so we dont think its the gauges fault. Anything else we can check besides pulling it apart? Its been through a couple oil changes with no change in pressure.
thanks.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31746
01/06/07 12:09 PM
01/06/07 12:09 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
thanks.
If it changed pressure from when it first was run to now, then there is something wrong.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: CJK440] #31747
01/06/07 12:12 PM
01/06/07 12:12 PM
Oklahoma
Oklahoma
thanks.
ok so how do we diagnose everything besides pulling it out and apart? meaning we hate to rip it out and find it was a worn pump drive or something. if also anyone could give us a breakdown of possibilites
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Mopar72Man] #31748
01/06/07 03:17 PM
01/06/07 03:17 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my 496 has the exact same oil press. as you describe, its been like that for the last 4 years and is still running great.(let me see if i can find some wood to knock on)
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: bonefish] #31749
01/06/07 05:45 PM
01/06/07 05:45 PM
The 340 currently in my car does the same thing. About 10-15 at idle when hot. If you step on it it can get all the way back up at 50, and get about 35-40 at cruise. Around 60 when its cold. Been this way for 6 years, still runs ok. Since the day i got it, it has been ticking like its got a wiped cam or lifter, and has this same oil pressure.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: bonefish] #31750
01/06/07 08:49 PM
01/06/07 08:49 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I would not say that that pressure is bad per se. I have had cars that ran like that without an issue.
But if the car first was run with very different psi numbers something changed and that would worry me.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: CJK440] #31751
01/08/07 12:36 PM
01/08/07 12:36 PM
dogdays Offline
dogdays  Offline
The pump drive either works or it doesn't. If it doesn't, you find out about it in a hurry and drag the car home because the engine is locked up.
My '93 Sub has 244,000 miles. When I start it up cold, the oil pressure will be about 35 psi at idle. When it warms up thoroughly, the oil pressure is around 10 psi at idle. get just a little off idle and the pressure comes up to 20, and it stabilizes at around 50 at cruise. I think what you have been describing is an engine set up with a little extra clearance in the bearings. The oil pump delivery is almost exactly proportional to rpm. At idle the pump can pump its entire output through the bearings while developing a pressure of whatever you said, 10 psi or something like that. As the engine speeds up, the oil volume delivered also increases and now you have "normal" oil pressure.
If you want to tear down the engine do it. Or, drive the car. It has gone 10K miles already and not locked up, so it must be doing something right.
You could also add a couple of bottles of special super-thick oil goop like Wynn's Motor Honey to get the viscosity up.
R.
A high-volume pump may be the answer if you can get the pan off without yanking the engine. If you do this put in a new high-quality oil pump drive.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: dogdays] #31752
01/08/07 01:08 PM
01/08/07 01:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
R.
He's already running a hi vol pump. Read his post.
His oil pressure is fine IMHO. Don't worry about it if the motor runs good.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: Challenger 1] #31753
01/08/07 01:31 PM
01/08/07 01:31 PM
dogdays Offline
dogdays  Offline
Sorry, I got on the end of this, didn't read all the previous posts.
R.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: dogdays] #31754
01/09/07 12:25 PM
01/09/07 12:25 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
in some rebuild kits there is a piece of fiber that goes in front of oil slinger, I had that come off and somwhat plug my oil pick up tube/
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: 70blackfish] #31755
01/09/07 12:35 PM
01/09/07 12:35 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
With a HV pump and 10K miles...that's really low to me. I overlooked that too...lol.
Re: Friends 'low' oil psi 340, only about 10,000miles [Re: moper] #31756
05/30/08 07:12 PM
05/30/08 07:12 PM
michigan
Flesh Offline
Flesh  Offline
michigan
I have a X-block stroker in my cuda and it is does about the same thing. Cold 70-80 psi, hot idle 10-20psi. Got me worried also at time . The oil pressure works like a tack and will go from 10 to 70 with the rpms. I do keep the idle real low though. I also notice if i shut down the car for a few minute(it cools off i think) and restart it at idle the pressure will be more on the 20 side. Seems the heat effects it a whole lot. Been driving it for 2 summer like this now and so far no break down. Read alot of post and i hear dont worry about it and i also hear tear it down alot. I chenged guages and sending unit to make sure that wasnt the problem it stayed the same. I would blame the pump myself i'am unsure whats in mine or mileage also but someone told me that it sounds like they threw a high pressure pump in for racing by the way it acts.
Page 2 of 3 1 2 3
