Re: Tubular K Member with Rack & Pinion
[Re: Dragula]
#3167125
08/10/23 05:00 PM
08/10/23 05:00 PM
Posts: 9,865 MI, usa
dvw
MI, usa
Well, at 138mph, its so smooth its not funny...Try that with a 50 year old OEM front end. Yes, they handle better, drive better, steering is more precise. I can think of quite a few OEM front-ends used by members on this site that are a good bit faster with no troubles. Dartin, Alguire, Casey, DVW to name a few. Seems to me some of those named, run strut cars, and nothing remotely OEM.....But go OEM I don't care, I get no deals on any of the units available. I can tell you, they are a very nice alternative to OEM for a lot of reasons. Including, better drivability. Next go around, I may even switch manufacturer's just because of the way they designed it and it would help for even more for header clearance than my current two setups. All 4 of us mentioned have current vehicles that run basically stock parts. At least 3 of us have been 150 mph or better. Personally mine runs 145-150 depending on ballast and weather. It has well over 900 passes. Drives perfect at speed. It has a lightened factory K frame, unmodified stock upper and lower control arms. The toe pattern has been zeroed in with heims and spacers replacing the outer tie rods. Though it was pretty close to start. My sons (Dizuster) and several friends all run 135-140 mph with totally stock stuff. As long as the components are in good shape, they drive fine. I can also say I've installed QA 1/Gerst stuff with a rack for customers. The out of the box geometry is not even close. The outer tie rod takes a 2"-3" shim to get it close. Not to mention the steering effort is very high an the turning radius is reduced. No thanks Doug
[Re: AndyF]
#3167143
08/10/23 06:46 PM
08/10/23 06:46 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Has there ever been a quantifiable before and after handling test preformed on these kits? I have worked on a charger with complete tubular front and rear suspension. Other than the brake upgrade and possible header clearance is there a handling benefit? I would think upper control arms allowing aggressive alignment specs would do the trick. Handling isn't the reason to switch. The factory Mopar setup works better for handling than the coil over and rack setups. The coil over and rack conversions are for space and weight. That is why drag racers convert to coil over and rack, or the higher buck ones go with a strut setup. Corner carvers stay with the factory torsion bar suspension since it works fine up to roughly 150 mph. Totally agree. I have Alterkation on the race car and could not see myself working on it without the additional room.
[Re: AndyF]
#3167165
08/10/23 08:34 PM
08/10/23 08:34 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
Has there ever been a quantifiable before and after handling test preformed on these kits? I have worked on a charger with complete tubular front and rear suspension. Other than the brake upgrade and possible header clearance is there a handling benefit? I would think upper control arms allowing aggressive alignment specs would do the trick. Handling isn't the reason to switch. The factory Mopar setup works better for handling than the coil over and rack setups. The coil over and rack conversions are for space and weight. That is why drag racers convert to coil over and rack, or the higher buck ones go with a strut setup. Corner carvers stay with the factory torsion bar suspension since it works fine up to roughly 150 mph. Thanks for the input
[Re: AndyF]
#3167196
08/11/23 12:28 AM
08/11/23 12:28 AM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
My Valiant has a rack mounted through the front of a stock k-frame with torsion bars. It took a little dojng to get the bump steer out, but my buddy sho did the work got it very near perfect. Car drives like a Caddy and steers backing up.
[Re: slantzilla]
#3167211
08/11/23 08:02 AM
08/11/23 08:02 AM
Posts: 623 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
See these arguments all the time, kinda pointless really. Like most things with our cars, its primarily driven by application and budget . I wanted the room and the ability to be able to work on the car easily. More precise steering, double adjustables and a full length, larger capacity oil pan with good ground clearance are a BIG bonus. I can remove the big 2 1/4" 4-1 headers off the Gen II Hemi in my A body on jackstands in no time. A little less weight too, so lots to like. It's been on the road for 8 years and has been flawless. Nothing wrong with the OEM parts esp if tweaked but for my application it was a no brainer
[Re: LAD 524]
#3167217
08/11/23 09:29 AM
08/11/23 09:29 AM
Posts: 4,690 On the parachute mount
n20mstr
INTERESTING COMMENTS, i have been over 160 in the 1/4 and 140+ in the 1/8. Stock and i mean ALL stock front end. Drives great. I have Tory K frame now and havent raced the car yet. However the room with these aftermarket front ends and the weight reduction is fantastic. All depends on what you are looking to do. IF you are on a budget, the stock stuff works great.
....BAD A$$ STREET CAR.....
[Re: AndyF]
#3167222
08/11/23 09:58 AM
08/11/23 09:58 AM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
Has there ever been a quantifiable before and after handling test preformed on these kits? I have worked on a charger with complete tubular front and rear suspension. Other than the brake upgrade and possible header clearance is there a handling benefit? I would think upper control arms allowing aggressive alignment specs would do the trick. Handling isn't the reason to switch. The factory Mopar setup works better for handling than the coil over and rack setups. The coil over and rack conversions are for space and weight. That is why drag racers convert to coil over and rack, or the higher buck ones go with a strut setup. Corner carvers stay with the factory torsion bar suspension since it works fine up to roughly 150 mph. All the Mopars in the late 60s and 70s ran 200 mph with torsion bar front ends with leaf springs in the back.
[Re: n20mstr]
#3167223
08/11/23 10:00 AM
08/11/23 10:00 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
INTERESTING COMMENTS, i have been over 160 in the 1/4 and 140+ in the 1/8. Stock and i mean ALL stock front end. Drives great. I have Tory K frame now and havent raced the car yet. However the room with these aftermarket front ends and the weight reduction is fantastic. All depends on what you are looking to do. IF you are on a budget, the stock stuff works great. Comp Chassis in Phoenix built my tube K coil over set up back in 2012. Absolutely ZERO regrets ever. Big EASY button when it comes to working on the car. One engine has custom mid/rear sump pan, other one runs a rear sump truck pan. I also took advantage of the new found space and had custom headers built for the W8 and the old Hedman Hustlers modified for more clearance. Wheels stay true on launch and rock steady down the track. I give it a huge race car thumbs up!
[Re: bobby66]
#3167236
08/11/23 10:54 AM
08/11/23 10:54 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
No pooping in anyones ice cream here. A statement was made about stock front ends and I as well as Doug have responded. In my case it has nothing to do with budget and I am sure Doug is the same. I just want to keep the car as stock as possible just cause. I have a "real" drag racecar and am very well aware of the advantages of its design over the 64. but in my case the +64 is just something to go have fun and do wheelies with. And it scores highly on both those fronts with a stock front end.
[Re: Al_Alguire]
#3167279
08/11/23 02:46 PM
08/11/23 02:46 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I built a custom front suspension for my 65 Dart and used stock upper and lower control arms. I duplicated the location of the mounting points of factory setup but used modified reversed lower ball joints to come up with a front steer rack to allow a big pan and lighten the car. Twenty six years later, I am very happy with it, and only made custom upper control arms to allow more caster.
[Re: gregsdart]
#3167350
08/11/23 06:52 PM
08/11/23 06:52 PM
Posts: 22,697 Bitopia
jcc
Bitopia
But a front steer solution as pictured has sacrificed proper Ackerman greatly, which might be in a very specific application acceptable, but seldom preferred.
[Re: jcc]
#3167375
08/11/23 08:12 PM
08/11/23 08:12 PM
Posts: 680 st.louis,mo.
dart games
st.louis,mo.
ive collect through out the years many pics of rack and pinion put into stock k frames.over the weekend there was a fastback cuda at a car show sunday i liked with a rack put in using stock k frame will copy off this one.he kept the stock upper and lower arms and is using torsion bars.i want to build my own using stock k frame.btw this was a blown 440 big block car
[Re: jcc]
#3167384
08/11/23 08:39 PM
08/11/23 08:39 PM
cudaman1969
fredericksburg,va
But a front steer solution as pictured has sacrificed proper Ackerman greatly, which might be in a very specific application acceptable, but seldom preferred. Never had a problem with the ackerman on the 68 Dart, it was done right! Backed up and turned the proper way (no outside wheel turning more than the inside) pinto rack, 74 Dart k-frame, lower ball joints swapped side to side. More info will cost ya.
[Re: cudaman1969]
#3167388
08/11/23 09:07 PM
08/11/23 09:07 PM
jcc
Bitopia
But a front steer solution as pictured has sacrificed proper Ackerman greatly, which might be in a very specific application acceptable, but seldom preferred. Never had a problem with the ackerman on the 68 Dart, it was done right! Backed up and turned the proper way (no outside wheel turning more than the inside) pinto rack, 74 Dart k-frame, lower ball joints swapped side to side. More info will cost ya. We agree then, there is a difference between "sacrificed proper Ackerman" and "never had a problem" ? For those on the sidelines who might be scratching their heads here, normal Ackerman in a front steering two axle vehicle, is defined as the intersection lines drawn thru the outer steering tie rod ends thru the lower balljoints to the center of the rear axle. It is assumed those lines are mirror image on the centerline of the car, when the front wheels are pointed straight ahead. Those lines need to be same angle whether tie rods are in front or rear of the front axle line. Meaning, the tie rods are closer on a rear rack IFS, and farther apart on a front rack car. That can't be changed significantly for proper Ackerman, period. Ackerman effect becomes more significant the smaller the turning radius.
[Re: jcc]
#3167399
08/11/23 10:25 PM
08/11/23 10:25 PM
cudaman1969
fredericksburg,va
But a front steer solution as pictured has sacrificed proper Ackerman greatly, which might be in a very specific application acceptable, but seldom preferred. Never had a problem with the ackerman on the 68 Dart, it was done right! Backed up and turned the proper way (no outside wheel turning more than the inside) pinto rack, 74 Dart k-frame, lower ball joints swapped side to side. More info will cost ya. We agree then, there is a difference between "sacrificed proper Ackerman" and "never had a problem" ? For those on the sidelines who might be scratching their heads here, normal Ackerman in a front steering two axle vehicle, is defined as the intersection lines drawn thru the outer steering tie rod ends thru the lower balljoints to the center of the rear axle. It is assumed those lines are mirror image on the centerline of the car, when the front wheels are pointed straight ahead. Those lines need to be same angle whether tie rods are in front or rear of the front axle line. Meaning, the tie rods are closer on a rear rack IFS, and farther apart on a front rack car. That can't be changed significantly for proper Ackerman, period. Ackerman effect becomes more significate the smaller the turning radius. A picture is worth a thousand words
[Re: cudaman1969]
#3167401
08/11/23 10:40 PM
08/11/23 10:40 PM
jcc
Bitopia
Maybe, but you don't have the right picture.
[Re: jcc]
#3167407
08/11/23 11:07 PM
08/11/23 11:07 PM
cudaman1969
fredericksburg,va
Maybe, but you don't have the right picture. That picture is the definition of ackerman, as long as the center line of both front wheels intersect with the center line of the rear axel, out a certain distance from axel, both front tires will not scrub. How it gets to that configuration is a matter of getting all the parts working right. I couldn’t find my Chrysler book that explained it so I just Googled it.
