Re: 1 year old Stihl chainsaw won't start - fixed, thanks
[Re: 340727dart]
#3166112
08/06/23 10:09 PM
08/06/23 10:09 PM
Posts: 21,705 N.E. OHIO, USA
A12
N.E. OHIO, USA
Go to Lowe's or Home Depot and get some of their pre-mixed gasoline. It's available in 40:1 and 50:1. The base gasoline is non-ethanol premium. The stuff stays good a long time. Me I would stick with the Stihl Motomix until the end of the warranty period.
[Re: A12]
#3166141
08/06/23 11:41 PM
08/06/23 11:41 PM
Posts: 4,335 Morrow, OH
markz528
Morrow, OH
Have a brand new Stihl wood boss chain saw. Less than a month old. So far have not figured out how to get it started quickly. But getting better at it. Last start took 6 strong pulls. It does not have a primer bulb - so far not impressed. The MS251 Wood Boss? Yup
[Re: markz528]
#3166147
08/07/23 12:08 AM
08/07/23 12:08 AM
Posts: 10,307 Someplace you aren't
SomeCarGuy
I have a 6-8 year old 180. Has the primer bulb. Can be hard to start maybe once every couple years. I run stabil 360 in e10 and never drain it. Try to start it once in the spring and once in the fall if I’m not using it. I’ve found that’s a good system for all my stuff, reminds me i need to start the snow blower soon. I never drain or run out anything. I used to run 87 or 89 in stuff. Lawn shop guy convinced me to use 93 last winter.
I want my fair share
[Re: markz528]
#3166151
08/07/23 12:33 AM
08/07/23 12:33 AM
A12
N.E. OHIO, USA
If the spark plug is not wet with fuel (good) and the crankcase is not full of fuel the factory starting procedure should work and the saw should start (cold) with primming and lever in the start position (partial choke and high idle speed). I've started hundreds of Stihl chainsaws, blowers, trimmers (hedge and line) and have demonstrated to new owners how to start them. Not trying to be cocky but this procedure works 99.99% of the time if there is nothing wrong (bad ignition, bad stop switch, etc.,) with the unit. With your MS251 press the primmer bulb 3 -5 times even if there is fuel in the bulb. Squeeze the throttle trigger completely WFO and move the "stop, run, start, choke" (SRSC) lever to the bottom "Full Choke" position. Pull the start cord until you hear or feel a "pop" or combustion. Nine out of ten times the saw will NOT start at this full choke position or point. When you feel that first pop move the SRSC lever up to the START or partial choke/high idle position WITHOUT squeezing or touching the throttle trigger. Pull the starter cord and it should start or come to life within one or two pulls. DO NOT attempt to feather the throttle trigger but let the saw run in the high idle position until you can feel warm exhaust at the muffler outlet with your hand. Once you have warm exhaust you can squeeze the trigger and kick off the lever from the start position and it will go right to the run. You should have an idle speed of around 2800 rpm to at the most 2950 rpm but nothing more. If this doesn't work then I'm tearing up my Stihl Silver Level Tech Certificate, throwing away all of my Stihl saws, blower, trimmers and buying corded and battery Milwaukee stuff . MikeR 1: Prime 3-5 times. 2: Squeeze throttle trigger, move control lever to full choke, lock lever into full choke position. 3: Pull start cord until you feel or hear one "pop". 4: Move control lever up one position to partial choke/start position. 5: Start/pull start cord. 6: Let run at high idle until you feel the exhaust get warm before squeezing throttle trigger. 7: In the run and warmed up position the idle should be 2800-2950 RPM.
[Re: A12]
#3166174
08/07/23 08:53 AM
08/07/23 08:53 AM
markz528
Morrow, OH
With your MS251 press the primmer bulb 3 -5 times even if there is fuel in the bulb. Squeeze the throttle trigger completely WFO and move the "stop, run, start, choke" (SRSC) lever to the bottom "Full Choke" position. Pull the start cord until you hear or feel a "pop" or combustion. Nine out of ten times the saw will NOT start at this full choke position or point. When you feel that first pop move the SRSC lever up to the START or partial choke/high idle position WITHOUT squeezing or touching the throttle trigger. Pull the starter cord and it should start or come to life within one or two pulls. DO NOT attempt to feather the throttle trigger but let the saw run in the high idle position until you can feel warm exhaust at the muffler outlet with your hand. Once you have warm exhaust you can squeeze the trigger and kick off the lever from the start position and it will go right to the run. You should have an idle speed of around 2800 rpm to at the most 2950 rpm but nothing more. If this doesn't work then I'm tearing up my Stihl Silver Level Tech Certificate, throwing away all of my Stihl saws, blower, trimmers and buying corded and battery Milwaukee stuff . MikeR 1: Prime 3-5 times. 2: Squeeze throttle trigger, move control lever to full choke, lock lever into full choke position. 3: Pull start cord until you feel or hear one "pop". 4: Move control lever up one position to partial choke/start position. 5: Start/pull start cord. 6: Let run at high idle until you feel the exhaust get warm before squeezing throttle trigger. 7: In the run and warmed up position the idle should be 2800-2950 RPM. Only problem is it does not have a primer bulb. Wish it did.
[Re: markz528]
#3166280
08/07/23 02:24 PM
08/07/23 02:24 PM
A12
N.E. OHIO, USA
Doesn't matter, when your pulling the start cord in the full choke position you're "primming" the carburetor in that mode. Eliminate primer step #1 and start (pun) with #2. New out of the box saws, trimmers, etc., without a primer are "primed" this way. We were instructed not to have the customer present during the first start because it sometimes takes a lot of "priming" and it may look like the unit is hard to start because of the first prime. Full choke "prime" until you hear or feel the first "pop", (only one pop! and) then to the partial choke and it will fire up.....going out on a limb (pun again) from hundreds of times doing this.
[Re: A12]
#3166305
08/07/23 03:22 PM
08/07/23 03:22 PM
markz528
Morrow, OH
Doesn't matter, when your pulling the start cord in the full choke position you're "primming" the carburetor in that mode. Eliminate primer step #1 and start (pun) with #2. New out of the box saws, trimmers, etc., without a primer are "primed" this way. We were instructed not to have the customer present during the first start because it sometimes takes a lot of "priming" and it may look like the unit is hard to start because of the first prime. Full choke "prime" until you hear or feel the first "pop", (only one pop! and) then to the partial choke and it will fire up.....going out on a limb (pun again) from hundreds of times doing this. Great! That is kinda where I was heading. This last time I did 2 pulls with choke and 4 without. Started on the 6th overall pull.
[Re: 340Cuda]
#3166459
08/08/23 09:34 AM
08/08/23 09:34 AM
Posts: 10,095 MN
JERICOGTX
MN
They guy that does my tree work uses Stihl battery powered chain saws and he says he and his crew love them. For trimming? I can see that. For cutting down BIG White Oak trees around here? We all use gas powered for that.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3166554
08/08/23 02:01 PM
08/08/23 02:01 PM
A12
N.E. OHIO, USA
They guy that does my tree work uses Stihl battery powered chain saws and he says he and his crew love them. For trimming? I can see that. For cutting down BIG White Oak trees around here? We all use gas powered for that. There's no electric chainsaw that I know of that will do this. This old tree was on our property and my neighbor and I cut it down, cut it up and then with a couple of front end loaders hauled it off to a corner of the farm property. I had my Stihl Farm Boss 271 and he had a German Solo saw that was pretty impressive. Should have heard and felt the thud when it dropped
[Re: JERICOGTX]
#3166884
08/09/23 05:32 PM
08/09/23 05:32 PM
Posts: 3,570 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
They guy that does my tree work uses Stihl battery powered chain saws and he says he and his crew love them. For trimming? I can see that. For cutting down BIG White Oak trees around here? We all use gas powered for that. They had one gas chain saw they took a tree down with. They trimmed off all the branches and cut the rest up for fire wood with the battery powered saws. Stihl makes battery powered saws with 16" bars.
[Re: A12]
#3167176
08/10/23 09:38 PM
08/10/23 09:38 PM
markz528
Morrow, OH
Doesn't matter, when your pulling the start cord in the full choke position you're "primming" the carburetor in that mode. Eliminate primer step #1 and start (pun) with #2. New out of the box saws, trimmers, etc., without a primer are "primed" this way. We were instructed not to have the customer present during the first start because it sometimes takes a lot of "priming" and it may look like the unit is hard to start because of the first prime. Full choke "prime" until you hear or feel the first "pop", (only one pop! and) then to the partial choke and it will fire up.....going out on a limb (pun again) from hundreds of times doing this. Great! That is kinda where I was heading. This last time I did 2 pulls with choke and 4 without. Started on the 6th overall pull. Your advice makes sense. I listened for a pop and got it started in 5 pulls. Getting better!
[Re: A12]
#3168334
08/16/23 04:47 PM
08/16/23 04:47 PM
Posts: 8,145 Arkansas
340727dart
Arkansas
Go to Lowe's or Home Depot and get some of their pre-mixed gasoline. It's available in 40:1 and 50:1. The base gasoline is non-ethanol premium. The stuff stays good a long time. Me I would stick with the Stihl Motomix until the end of the warranty period. My Stihl chainsaw is over a year old and the only fuel I've ever used is the premix stuff I get from Lowe's. Even after sitting several months in my storage container, with the gas in it, the saw fires right up within three or four pulls.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
