Page 3 of 5 1 2 3 4 5
Re: How much steam from W9's naturally aspirated? [Re: bdaz smblk] #316432
05/13/09 09:01 PM
05/13/09 09:01 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
If I had it to do all over I would use a tall deck block.It seems to make good power I just need everything to be right to get it to run like it should.I've been a 5.70 flat at 123 in the 1/8 and only a 9.03 at 150 so far but only has 3 test passes sense Steve Taylor at prc carbs got my carbs working good.Good luck with yours.Kenny
do you know what they did to get them to work..
Re: How much steam from W9's naturally aspirated? [Re: plycuda] #316433
05/13/09 09:10 PM
05/13/09 09:10 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
No I don't I wish I did you would have been the first I would have told.Steve just told me they weren't even close.I now he changed all the air bleeds and he said the float weights weren't right.I only run 6# of fuel pressure now and run the floates real real low.I only have $3,900 in these carbs now but atleast they work I guess.Good luck with yours and hope to see you guy's soon.Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: How much steam from W9's naturally aspirated? [Re: bdaz smblk] #316434
05/13/09 09:24 PM
05/13/09 09:24 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I'm gona try to go to mason dixon but my junk is still apart. I'm about to give up on cars and go fishing, you can't get anything done anymore. Let alone get it done right.
Post deleted by moparts [Re: plycuda] #316435
05/13/09 10:48 PM
05/13/09 10:48 PM
Re: How much steam from W9's naturally aspirated? #316436
05/13/09 10:59 PM
05/13/09 10:59 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Kenny I thought you went 9.0's with the W9 set up and not with the W8's. Whats you're fastest time with the W8's vs W9's and single four vs 2-4 set up.I should know this but as you know I can't remember S##t.
How many CC intake runner and what size valves were in you're W9's
And tell Evil Knevil no tricks on that Harley or he/ll end up walking like me.
I've been a 9.03 with the w-8's and a 9.13 with w-9's both with single four.The w-8's have 2.250 and 1.55 valves and the w-9's were 2.200 1.65 valves.I don't remember the cc intake runner.I'll tell dad to.Tell Mike to come buy my bike.Later Kenny
Re: How much steam from W9's naturally aspirated? [Re: LA360] #316437
05/14/09 12:04 AM
05/14/09 12:04 AM
Huron, South Dakota, United St...
dustyhof Offline OP
dustyhof  Offline OP
The average guy isn't going to pay the $$$ for a set of CFE W8's, pure and simple. I had some 13 degree CFE W8's and Sheet metal Intake for sale at well under what they cost and they're still sitting here.
A top end that makes that kind of power is going to set you back around 10K give or take.
AL....
Correct me if I'm wrong. I don't know if any dealers still had any W9's still on the shelf, but a year ago, when I had my Mopar dealership parts guy look for a set, he said there were a couple on the shelf yet at another dealership. The price was right around $1300 I think. Valves and springs?=$600? CNC porting=$1100, valve job=$150, hone valve guides=$75, Intake=$450?, Port intake=$100. Other little stuff that arises for good measure, $400? Grand total of $4,175. Not far form the Indy's my buddy just put on, and much more power potential. That's why I was kinda leaning that direction. Is my math way off? It's hard to justify another 6K for 150-200 more HP.
Re: How much steam from W9's naturally aspirated? [Re: dustyhof] #316438
05/14/09 07:37 AM
05/14/09 07:37 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
I ask again, why not W8's? A set of CNC ported Nascar W8's can be bought cheaper than you can do the W9's for with more power potential. Guys like Chris and Kenny that are running a n/a class can justify the cost of the CFE's but for the average bracket racer or if you're going to use a power adder the Nascar W8's will work just fine.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: How much steam from W9's naturally aspirated? [Re: Plumb Wired] #316439
05/14/09 07:52 AM
05/14/09 07:52 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Mike Gray
X2
I wouldn't consider a W-9 until the supply of used W-8s have dried up. Cheaper with more potential.
Re: How much steam from W9's naturally aspirated? [Re: jim sciortino] #316440
05/14/09 08:19 AM
05/14/09 08:19 AM
mid Ga.
W5Dart378 Offline
W5Dart378  Offline
mid Ga.
I've just gone to the 270cc chapman alcohol W9 head from a 220cc W5. Big difference in power band. My combo was pretty much dialed for the W5s, rpm around 6800 in the 1/8th on the spray. Ive made 6 passes so far. Got to changes gears and converter for sure.went 6.80 on motor at 108.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: How much steam from W9's naturally aspirated? [Re: bdaz smblk] #316441
05/14/09 11:59 AM
05/14/09 11:59 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
My Demon ran High 9's and was regularly street driven. It idled nice at stoplights and had a 3.91 gear and a 10" converter. W9/R3 X 474CI It weighed 3180 with me in it.
SRT DEMON ONE SEAT
Re: How much steam from W9's naturally aspirated? [Re: Ron Silva] #316442
05/14/09 12:01 PM
05/14/09 12:01 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Engine
SRT DEMON ONE SEAT
Re: How much steam from W9's naturally aspirated? #316443
05/14/09 01:25 PM
05/14/09 01:25 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
they took off my training wheels and never told me.paybacks are you know what!
Re: How much steam from W9's naturally aspirated? [Re: HMcCandless_Jr] #316444
05/14/09 06:30 PM
05/14/09 06:30 PM
Im going to dyno with one in a few days. Its a 347inch with a hogan intake. Should make close to well we will see. I will sell the top half if interested. The intake is for a 9 inch block.
WOW thats a lot of head for 347",it should be a 9000 rpm'er
Post deleted by moparts #316445
05/14/09 07:32 PM
05/14/09 07:32 PM
Re: How much steam from W9's naturally aspirated? #316446
05/15/09 06:28 AM
05/15/09 06:28 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I like this post keep em coming with more w combo,i like hear about fast SB
Re: How much steam from W9's naturally aspirated? [Re: Otherlane] #316447
05/15/09 09:13 AM
05/15/09 09:13 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
How about some cam spec's for any of these combos.. The w9's should be plenty for most of us.
Re: How much steam from W9's naturally aspirated? [Re: Dos Snails] #316448
05/15/09 04:56 PM
05/15/09 04:56 PM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
I have a 4 in stroke x 4.10 bore w9 engine. The head are chapman cnc with alchohol chamber milled to 58cc.
Comp roller with 264 at 50 and 717 lift. Bigs 1050 and made 751hp 614tq.
Last weekend car which is 3520 with me in it went 1.38 60ft and 9.85/135.85 mph. Car is full interior with monos and caltracs, and has a 29.5x10.5 slick.
Full street registration and all steel.
Re: How much steam from W9's naturally aspirated? #316449
05/15/09 05:53 PM
05/15/09 05:53 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
Hey Jimmy here is pictures of the new hoods
Re: How much steam from W9's naturally aspirated? [Re: webemopes] #316450
05/15/09 05:56 PM
05/15/09 05:56 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
Some more
Re: How much steam from W9's naturally aspirated? [Re: webemopes] #316451
05/15/09 05:58 PM
05/15/09 05:58 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
Sorry to high jack the post but one more of kennys
