Gear drive binding
#3163950
07/28/23 04:32 PM
07/28/23 04:32 PM
Posts: 554 Kentucky
clovis
Kentucky
Well I thought I was in the home stretch finally getting this engine done. I put the pan on today, was oil priming when all of a sudden the motor locked up. I was rotating the engine over as I was running the drill. Got everything oiling except driver side rocker shaft when it locked up. Pulled the pan and front cover, only to find my Pete Jackson gear drive bound up. I pulled the idler gear and rocker arms, and everything turns over nice and smooth. Put the idler gear back in and rolls over smoothly once again. I didn’t find anything in the gears, just curious what would cause the binding. I’m semi debating putting the chain on but it is crazy how there is zero play with the gear drive. Would higher spring pressures cause a problem with the gear drive?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Gear drive binding
[Re: clovis]
#3163996
07/28/23 08:28 PM
07/28/23 08:28 PM
Posts: 3,024 NY
B1duster
NY
Did you check piston to valve clearance ? Put the rockers back on and try again. I ran a PJ gear drive for a few years. Not sure if block needs to be clearanced for it.
I did some searching… they say you may have to "clearance" the block for proper idler clearance.
[Re: Cab_Burge]
#3164045
07/29/23 08:39 AM
07/29/23 08:39 AM
Posts: 554 Kentucky
clovis
Kentucky
First pictures where the engine is upside down is where it is bound. The second picture is after I took a pry bar to the idler, checked the rotation of the crank and cam (which was good) and re-installed the idler. It turns over very smoothly without the rocker arms on it. My spring pressures are over 400 open now and I am curious if that is part of the problem. The motor is hard to turn over with the rockers arms on it, as you can definitely feel the spring pressure.
[Re: clovis]
#3164047
07/29/23 08:57 AM
07/29/23 08:57 AM
Posts: 2,530 PA
moparacer
PA
400 lbs spring pressure is nothing. Definitely shouldn't bind a gear drive. Did you verify you had sufficient lash like Rick mentioned in the second post? If you have lash, turn the motor over and it goes away, something is not right. Don't run it. I never used a PJ gear drive but looking at that dual idler setup I would think if a block has been line bored that would tighten the lash, but I dont know how you would deal with that? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I used Milodon single Idler setups before and you could adjust the lash to compensate. Much better IMO.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3164053
07/29/23 09:36 AM
07/29/23 09:36 AM
Posts: 554 Kentucky
clovis
Kentucky
I’m headed to the shop now to measure the lash. Do you check it with tension on the cam gear (rockers installed) or without?
[Re: clovis]
#3164060
07/29/23 10:11 AM
07/29/23 10:11 AM
Posts: 554 Kentucky
clovis
Kentucky
Measuring like is shown, I get .010 on the left gear. The right side gear has zero.
[Re: clovis]
#3164065
07/29/23 10:21 AM
07/29/23 10:21 AM
Posts: 554 Kentucky
clovis
Kentucky
Measuring from the cam gear I get .017.
[Re: Stanton]
#3164084
07/29/23 11:32 AM
07/29/23 11:32 AM
Posts: 554 Kentucky
clovis
Kentucky
I was reading the instructions for the summit brand set and it said the idler gear (small gear) should have .005-.0075 vertical movement. Measuring as shown in the picture the lash is virtually nil and there is no vertical movement.
[Re: clovis]
#3164127
07/29/23 03:01 PM
07/29/23 03:01 PM
Posts: 763 Southington Ct.
turbobitt
Southington Ct.
I have a question, Is that metal debris chunk on the idler in picture 1(Left) on a tooth near the 6 o-clock position ? Is there anything behind the idlers to get caught on or bind on ? Like an oil passage or casting flash ? What controls the fore and aft movement of the idlers ? How about he cam thrust ?
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: clovis]
#3164128
07/29/23 03:04 PM
07/29/23 03:04 PM
turbobitt
Southington Ct.
I was reading the instructions for the summit brand set and it said the idler gear (small gear) should have .005-.0075 vertical movement. Measuring as shown in the picture the lash is virtually nil and there is no vertical movement. I hate to be a critic about this but I see metal debris in this pic also. Very top of pic on gear.. AG.
[Re: clovis]
#3164148
07/29/23 04:50 PM
07/29/23 04:50 PM
Posts: 2,530 PA
moparacer
PA
I was reading the instructions for the summit brand set and it said the idler gear (small gear) should have .005-.0075 vertical movement. Measuring as shown in the picture the lash is virtually nil and there is no vertical movement. Nope that won't work.zero clearance at any point bad things will happen most likely. I would put a chain on it.
[Re: moparacer]
#3164159
07/29/23 05:46 PM
07/29/23 05:46 PM
Posts: 4,771 Moved to N.E. Tennessee
GomangoCuda
I was reading the instructions for the summit brand set and it said the idler gear (small gear) should have .005-.0075 vertical movement. Measuring as shown in the picture the lash is virtually nil and there is no vertical movement. Nope that won't work.zero clearance at any point bad things will happen most likely. I would put a chain on it. The dual idler gear floats. Push one idler gear tight into crank and cam gears and then measure the vertical movement at the other idler gear. If there still is no movement then perhaps your block has been line bored which moves the crank up a few thou.
[Re: GomangoCuda]
#3164160
07/29/23 05:53 PM
07/29/23 05:53 PM
Posts: 2,530 PA
moparacer
PA
I was reading the instructions for the summit brand set and it said the idler gear (small gear) should have .005-.0075 vertical movement. Measuring as shown in the picture the lash is virtually nil and there is no vertical movement. Nope that won't work.zero clearance at any point bad things will happen most likely. I would put a chain on it. The dual idler gear floats. Push one idler gear tight into crank and cam gears and then measure the vertical movement at the other idler gear. If there still is no movement then perhaps your block has been line bored which moves the crank up a few thou. That is what I said earlier. Line bore could remove the clearance and then the problems start.
[Re: moparacer]
#3164213
07/30/23 01:34 AM
07/30/23 01:34 AM
Posts: 3,024 NY
B1duster
NY
