Re: How much steam from W9's naturally aspirated?
[Re: FASTFISH420]
#316414
05/13/09 12:50 PM
05/13/09 12:50 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Jim, There is nothing wrong with a 15 degree head..Tell you the truth..if I was to do a new head it would be a 13 degree..The 15 and up motors like rpm..when we changed to the 10 degree..the rpm came down..which is easier on the motor.but this is also with over 400 inches..but the 9400 rpm thru the traps is fun. A 360 cube with a 10 degree is another story..
What kind of rpm did the motor like on the dyno?..my 16 degree would go around 8900 before it would fall off?
It peaked at 8100 and 8200, we only pulled it to 8500, where it was down only 5hp.
This was with a 2, 2.125, 2.250 step header 24in primaries and a Burns merge collector. 2in Wilson spacer and C-25.
[Re: jim sciortino]
#316415
05/13/09 12:54 PM
05/13/09 12:54 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Should run pretty strong..the car you are putting it in is pretty light.. correct? I should of used those headers to dyno mine.. ![](/ubbthreads/images/graemlins/grin.gif)
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: FASTFISH420]
#316416
05/13/09 01:25 PM
05/13/09 01:25 PM
jim sciortino
Trumbull,CT.
We're thinking 2900 with driver.
I wish I knew you needed them. Would have shipped them to ya in a heartbeat.
I'm thinking you're peaks would go up with the correct header and whatever fine tuning you're doing to the manifold and spacer. That puppy will make 1000+ with a little fine tuning.
[Re: FASTFISH420]
#316417
05/13/09 01:30 PM
05/13/09 01:30 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I never dynoed mine but it was a 4.185 bore with a 4.00 stroke standard port w-9 in a 3,120# 72 dart with 29.5x10.5 slicks and went a 9.13 @ 147 they were cnc ported by chapman and shifted the car at 7,500.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: Otherlane]
#316421
05/13/09 02:09 PM
05/13/09 02:09 PM
Posts: 428 wappinger falls new york
Jimi_Vignogna
I can't believe no one had bought jimi w7 motor. if someone wants to go high 8s there's a motor for you. I wonder how much power would that motor make with a good set of w8s?
i have a 390" version with w8's from cfe and it made 936 hp average.
i also have a 300" w8 with single 750 so far it has been a best of 785hp average
[Re: bdaz smblk]
#316425
05/13/09 03:24 PM
05/13/09 03:24 PM
Posts: 830 east coast
Otherlane
east coast
Ok I talk with your brother I think that what he said and you guys build your own motors. if I remember right a couple yrs ago you had a set of w heads for sale at the mopar race..Cant remember if they were 8s or 9s. if anyone haven't seen this dart its so clean
[Re: Otherlane]
#316426
05/13/09 07:55 PM
05/13/09 07:55 PM
Posts: 6,151 Melbourne , Australia
LA360
The average guy isn't going to pay the $$$ for a set of CFE W8's, pure and simple. I had some 13 degree CFE W8's and Sheet metal Intake for sale at well under what they cost and they're still sitting here. A top end that makes that kind of power is going to set you back around 10K give or take. AL....
Alan Jones
[Re: bdaz smblk]
#316427
05/13/09 08:16 PM
05/13/09 08:16 PM
Posts: 3,456 Out West
408strokerdart
Out West
Jimi, very nice power. Bdaz smblk, have you race the dart at MIR? If so are you still running two dominators? what's the spec on the engine if you don't mind telling us?
Yes I was at MIR having major problems with two prosystems dominators but prc carbs has fixed that problem.It's a 440" cfe w-8 with two dominators flat top je pistons with a 800 lift roller .It is a 9" deck block with 4.185 bore 4.000 stroke 6" rods.
Wow, where did you put the ring pack in that motor? C/H must have been nothing. I had to go 5.9" long rod with my 3.79 stroke 9" deck motor.
[Re: 408strokerdart]
#316428
05/13/09 08:22 PM
05/13/09 08:22 PM
bdaz smblk
south central pa
It is tight.It only has a .980 c/h.
[Re: bdaz smblk]
#316429
05/13/09 08:24 PM
05/13/09 08:24 PM
408strokerdart
Out West
Congrats on stuffing that much arm into such a short deck motor. ![](/ubbthreads/images/graemlins/thumbs.gif)
#316431
05/13/09 08:47 PM
05/13/09 08:47 PM
bdaz smblk
south central pa
If I had it to do all over I would use a tall deck block.It seems to make good power I just need everything to be right to get it to run like it should.I've been a 5.70 flat at 123 in the 1/8 and only a 9.03 at 150 so far but only has 3 test passes sense Steve Taylor at prc carbs got my carbs working good.Good luck with yours.Kenny
