Re: Starting a rebuilt engine out of the car
[Re: topside]
#3165727
08/05/23 11:29 AM
08/05/23 11:29 AM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I wouldn't use anti freeze at this point either. And you can make an argument either way as to whether to run a thermostat or not. I usually do, but you have to keep a closer eye on the temp as you are restricting the water flow even when the 'stat is open. But I don't use distilled water. At the risk of starting a debate on this minor point, here is an interesting article from Rislone as to why I don't: https://rislone.com/blog/cooling/why-you-should-never-use-distilled-water-in-your-cooling-system
Master, again and still
[Re: Cab_Burge]
#3166361
08/07/23 07:57 PM
08/07/23 07:57 PM
Posts: 20,622 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
UTG Uncle Tony's Garage has a Youtube Video from a few months back that covers how to set everything for a quick start up. Mopar Action Magazine has a tech article with the same topic covered as well. Carb set up, dist location, ect. Might be on their website maybe? https://www.moparaction.com/2021/01/29/mopar-action-tech-guide/
