Re: 360 balance issue
[Re: Bumbalawski]
#3163067
07/25/23 01:01 PM
07/25/23 01:01 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Engine was rebuilt. New pistons? New pistons with weights very similar to OE pistons?
I can add that, 30 years ago I built a 360 with trw forged replacement pistons. Weights very close to stock. I used the B&M flex plate, and balanced it myself.
It needed more weight on the rear than what the flex plate provided. I ended up adding three fairly large holes to the flexplate to increase the amount of imbalance to get the crank to balance out.
The front, which had the factory balancer, was fine.
[Re: Bumbalawski]
#3163080
07/25/23 01:52 PM
07/25/23 01:52 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
here are several different designs of 360 LA balancers but the external weight is the same for all.
As noted above, the problem is probably incorrect weight replacement pistons.
