Re: How "wild & crazy" have you gone w/ converter for street?
[Re: JERICOGTX]
#3166246
08/07/23 01:07 PM
08/07/23 01:07 PM
Posts: 9,525 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Wow.... inflation and a few years has really moved the costs up.
I run this on the support that holds the hood latch so its a couple inches in front of the radiator. B@M 70297
Might be overkill but at the time it was easier to buy a 727 from a decent builder vs build so I didnt mind spending a bit more and might be doing the placement more under the car to the rear during the next revamp.
STOP POTATO HATE!
[Re: Bad340fish]
#3166263
08/07/23 01:45 PM
08/07/23 01:45 PM
Posts: 10,041 MN
JERICOGTX
MN
I use an old permacool (i think?) trans cooler I bought off the shelf at advance auto parts 25 years ago, lol. What is a "Trans Cooler"??? LOL!!! It is used to keep the dustless fluid cool in the magic viscous torque multiplying device with lightning fast shifts. Sounds like a foreign language to me...
69 GTX
68 Road Runner
[Re: moparx]
#3166290
08/07/23 02:44 PM
08/07/23 02:44 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Mine pulls air through. Some other brands say they can be either clearly by a polarity reversal however the B@M instructions say it should pull and if not correct the polarity. But it does not say you should not or it would cause damage. I have it on the built in T stat and a bypass switch. The fan hardly ever kicks on by itself. I will try to snap an installed pic today or tomorrow. https://documents.holley.com/70297.pdf
STOP POTATO HATE!
[Re: AndyF]
#3166746
08/09/23 08:45 AM
08/09/23 08:45 AM
Posts: 1,147 Loudoun County, VA
Brad_Haak
Loudoun County, VA
The driveshaft speed sensor on your data logger will tell you what the stall speed is Me no have data logger, but I have upgraded to a playback tach
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
