Re: .090 overbore on '65 383?
[Re: lakerism]
#3162425
07/23/23 04:26 PM
07/23/23 04:26 PM
Posts: 4,832 Star Idaho
67vertman
Star Idaho
I wouldn't run an engine on a regular bases at 0.90. If it was my matching number engine and I only took it to cruises and weekend driver, then that may be a different story.
My Monster are real!
Living within your means makes life pretty easy.
[Re: Sniper]
#3162453
07/23/23 05:09 PM
07/23/23 05:09 PM
Posts: 5,960 ohio
ruderunner
ohio
Only a sonic check can answer this question for you This is the real answer. But, as stated, what is your REALISTIC goal? Weekend runs with the grandkids for ice cream? Sure, run forever that way. Bracket racing ricers? You'll embarrass yourself. FAST racing? Could work, how much you want to spend?
Angry white pureblood male
[Re: ruderunner]
#3162457
07/23/23 05:20 PM
07/23/23 05:20 PM
Posts: 10,763 North Dakota
6PakBee
North Dakota
If you really like the car and the price is right, I'd go for it. What's the worst that could happen? That you'd need to get another 383? Or sleeve the engine you have if it went south? I'm not even going to ask where someone got a 0.090 over piston set.
[Re: 6PakBee]
#3162494
07/23/23 06:43 PM
07/23/23 06:43 PM
Posts: 1,850 South Bend
John Brown
South Bend
If you really like the car and the price is right, I'd go for it. What's the worst that could happen? That you'd need to get another 383? Or sleeve the engine you have if it went south? I'm not even going to ask where someone got a 0.090 over piston set. 400 B engine pistons? Might even be a 400 block, so a casting number check would be in order.
[Re: John Brown]
#3162571
07/23/23 10:09 PM
07/23/23 10:09 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
If you really like the car and the price is right, I'd go for it. What's the worst that could happen? That you'd need to get another 383? Or sleeve the engine you have if it went south? I'm not even going to ask where someone got a 0.090 over piston set. 400 B engine pistons? Might even be a 400 block, so a casting number check would be in order. What I think too, 400 piston 4.34 is .090 over 4.25
[Re: slantzilla]
#3162635
07/24/23 08:42 AM
07/24/23 08:42 AM
6PakBee
North Dakota
Never thought about using a 400 piston. Looking at what's available, it seems you could find an equivalent compression height. Stock it looks like the 400 would be over 0.030 in the hole compared to the 383.
[Re: lakerism]
#3162683
07/24/23 11:35 AM
07/24/23 11:35 AM
Posts: 6,330 nowhere
Sniper
nowhere
A BB stick car in great shape for $20k? If it were an AC car you'd be complaining about how I bought it already.
[Re: topside]
#3162790
07/24/23 03:00 PM
07/24/23 03:00 PM
Posts: 3,125 N.W. Florida
Fat_Mike
N.W. Florida
It could be that someone just "fat-fingered" .060, I suppose. Looks pretty decent for $20K in this market; wouldn't surprise me if a dealer buys it and re-lists closer to $30K. Agree, "all original" is an exaggeration, but I'm not seeing any big issues. Like every car, all depends on an in-person inspection. Nope. If you go to the link the OP provided on page 1 and scroll to the bottom, someone asked the question. The seller clarified that it is indeed .090 over. Regardless, it appears to be a nice car at a good price.
[Re: lakerism]
#3163407
07/26/23 02:57 PM
07/26/23 02:57 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
That looks great. I'd probably buy it and worry about engine specs later.
Rich H.
Esse Quam Videri
