Dana yolk #3160117
07/16/23 10:05 PM
07/16/23 10:05 PM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
Needing to restore my 1970 dana (410) rearend. I have an aftermarket ( direct connection) pinion yolk
I'm not sure what the original part # is in order to look for it. Any help will be greatly appreciated. Thanks in advance
Re: Dana yolk [Re: Roadrunner440-6] #3160280
07/17/23 02:05 PM
07/17/23 02:05 PM
Got an answer...#7290
Re: Dana yolk [Re: Roadrunner440-6] #3160405
07/17/23 10:07 PM
07/17/23 10:07 PM
New York, USA
Chargerfan68 Offline
New York, USA
Just my opinion:
That will get you the right fitment part but that is the yoke size classification, not the actual part number for your car. But, as long as you get the yoke that works, which you should with that info.
