Re: Torsion bar recommendation [Re: poorboy] #3160353
07/17/23 06:59 PM
07/17/23 06:59 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
The block is aluminum as well. I'm not looking to drop money on new torsion bars just to do it, I would just rather do it now since everything is already ripped apart. I just didn't know if they wear out that much considering they're now 50 years old.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Torsion bar recommendation [Re: 73cuda340] #3160476
07/18/23 10:42 AM
07/18/23 10:42 AM
AndyF Offline
AndyF  Offline
A 1.00 inch torsion bar is 50% stiffer than a 0.900 bar. Spring rate for torsion bars is diameter to power of four so a small change in diameter makes a big difference.
The rule of thumb for street handling is to have the bar rate be 10% of the front end weight. Typical E/B body car has about 1800 lbs up front so a 180 lb rate bar is recommended which is a 1.00 inch bar.
