Re: Picked up another unusual 440 block and crank. [Re: 71GTX471] #3159585
07/14/23 01:39 PM
07/14/23 01:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Originally Posted by 71GTX471
Originally Posted by John_Kunkel
Originally Posted by migsBIG
The second crank has this weird type of machined riddling on the front, something I’ve never seen before
It's called knurling, used to expand/restore the diameter of a shaft that's been worn undersized or otherwise damaged.
I have an NOS 440 crank with the snout knurled from the factory.
That I would like to see.
Re: Picked up another unusual 440 block and crank. [Re: NITROUSN] #3159650
07/14/23 07:21 PM
07/14/23 07:21 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
I have several small block cranks that came from untouched motors, very very common to knurl things.
Migs, im sure you know there are many many people around with the correct font stamps and ways to use them. I know a couple who will stamp any block any way you want it but ya got to go to them. If I ever got close to them id melt the tips off.
STOP POTATO HATE!
Re: Picked up another unusual 440 block and crank. [Re: moparx] #3160306
07/17/23 03:25 PM
07/17/23 03:25 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Knurling piston skirts was a common thing rather than replacing the pistons when doing a refresh on an engine back in the earlier days.
I was actually recently looking for a machine shop that could still do the work. But haven't found any that do.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Picked up another unusual 440 block and crank. [Re: hp383] #3160580
07/18/23 01:49 PM
07/18/23 01:49 PM
moparx Offline
moparx  Offline
i forgot about piston knurling. thanks for shaking the cobwebs ! up
beer
Re: Picked up another unusual 440 block and crank. [Re: hp383] #3160583
07/18/23 01:59 PM
07/18/23 01:59 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Knurling on parts that see constant friction movement (like pistons, valve guides, etc) has a down side, knurling reduces the contact surface area and the part will wear quicker. Knurling a part like a crank snout to restore its diameter is different since the balancer is a press fit and there's no constant movement.
As I said earlier, the factory was reluctant to scrap a part if it could be saved with a simple procedure.
Re: Picked up another unusual 440 block and crank. [Re: moparx] #3160585
07/18/23 01:59 PM
07/18/23 01:59 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
I have one similar to this. I used to do many old farm tractor ring jobs and valve jobs/clutches and knurling was the norm.
I recently pulled a 318 apart and they were all knurled. From a rebuild.
STOP POTATO HATE!
Re: Picked up another unusual 440 block and crank. [Re: Mr PotatoHead] #3160589
07/18/23 02:05 PM
07/18/23 02:05 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Seen better days.
STOP POTATO HATE!
Re: Picked up another unusual 440 block and crank. [Re: Mr PotatoHead] #3160593
07/18/23 02:11 PM
07/18/23 02:11 PM
moparx Offline
moparx  Offline
watching that video you posted kinda reminded me of my machinist days, when someone would get the stop set a few thou too close to the chuck......... whistling panic laugh2
beer
