Re: 440 6pk Cam Selection Tips [Re: B1MAXX] #3158654
07/10/23 09:34 PM
07/10/23 09:34 PM
Originally Posted by B1MAXX
Lobe separation angle is simply the angle between the the lobe centers.
confused In relation to what work?
Re: 440 6pk Cam Selection Tips [Re: Cab_Burge] #3158697
07/11/23 12:09 AM
07/11/23 12:09 AM
AndyF Offline
AndyF  Offline
LSA isn't in relation to anything else. The LSA exists even if the camshaft is sitting in a box or on the bench.
Re: 440 6pk Cam Selection Tips [Re: Cab_Burge] #3158704
07/11/23 01:19 AM
07/11/23 01:19 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Nothing, that's it smile
Re: 440 6pk Cam Selection Tips [Re: Cab_Burge] #3158708
07/11/23 02:14 AM
07/11/23 02:14 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
[/quote] tsk Don't spread misinformation about LSA, Lobe separation angles means when the cam lobe is at max lift from TDC, the same lobes ground on 104 LSA will have a lot rougher idle with less manifold vacuum than a cam with the same lobes ground on a 112 LSA due to less over lap at TDC on the wider LSA work scope twocents
Cab,
With all do respect, I'm certainly not intentionally spreading misinformation about camshaft characteristics. However, I did make a mistake, and I think it's causing the confusion. In my simple example, I should have said: "A general rule of thumb is that the Wider the LSA (bigger number) the more tame your idle characteristics will become and more engine vacuum you'll produce. So an LSA of 112 will idle smoother than say a Tighter LSA of 108 degrees." My mistake was that I confused the terms Tighter and Wider.
Other than that, I don't see any conflict in the information I've provided the topic starter and the information you provided. I hope this helps clear things up. Sorry for any confusion.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 440 6pk Cam Selection Tips [Re: Cab_Burge] #3158742
07/11/23 08:22 AM
07/11/23 08:22 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
From the centerline of one lobe to the other. Thats it.
Re: 440 6pk Cam Selection Tips [Re: B1MAXX] #3158789
07/11/23 10:39 AM
07/11/23 10:39 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Something around 239/243 @.050 and .620/.620 gross lift (1.6:1 rockers) would work really nice and let you get the heads to breathe.
I would run a 109 lobe center in maybe at +2 (107 ICL)
Something like the old Ultradyne NF70/NF62 .904 (Chrysler lobe)
This would give you a nice 162/164 degrees @.200 but mild seat to seat so the idle will be sweet.
I think Bullet still grinds the old Harold U/D cams
A solid flat tappet adjusted for lash is about 8-10 degrees smaller at .050 than a hydraulic so this is really a pretty mild cam. that's only 23 degrees of @.050 overlap if my math is still good, lol. With a dual plane six pack and headers that's about perfect.
EDIT:
This Hughes grind is dead on what I would consider picking:
Category : D- Big Block (Low Deck) : Camshaft : Flat Tappet, Solid
HUG STL3842BS3-9
BB SLD FLAT TAPPET CAM 238/242 -109ÂșLSA
3 BOLT .372"/.376" LOBE LIFT
$241.35
Flat tappet solid big block "B/RB" camshaft.
Hughes "real" Chrysler cam
All of our big block solid cams are three bolt.
Basic guidelines (These are not absolutes, just guidelines to help you get close on a cam choice)
Use: Street Performance, high rise dual plane intake & headers. Mildly ported cylinder heads
Idle: Noticable
Converter: 3000 stall +
Rear gear: 3.55+
WIZE
In Car:
