Re: Allowable flexplate to converter clearance?
[Re: MarkZ]
#3157709
07/06/23 10:35 PM
07/06/23 10:35 PM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
What bolts are using? Should have a real thin head on it.
I've got a set of brand new 7/16" ARP converter bolts if you need them. I can bring them to work tomorrow if you do. Mark, Appreciate the offer but I'm thinking these are exactly the same bolts I am using. 1) crank to flexplate - ARP 200-2903, 7/16" 2) flexplate to converter - ARP 240-7302, 7/16"
[Re: B1MAXX]
#3157761
07/07/23 10:19 AM
07/07/23 10:19 AM
Posts: 12,275 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yes, hopefully common sense comes into play.
Master, again and still
[Re: jwilson 61]
#3157793
07/07/23 12:49 PM
07/07/23 12:49 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Make sure your flexplate to crank bolt heads aren't too thick causing the front of the converter to hit the heads of the bolts before allow the converter to go fully into the crank register This seems to be more common with 8-bolt cranks...bolt heads will actually leave noticeable witness marks in the converter.
[Re: Cab_Burge]
#3157899
07/07/23 09:38 PM
07/07/23 09:38 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just a light mist of water and taking your time grinding will prevent any discoloring. Not at all hard to do. Besides, any discoloring would be limited to the surface of the bolt head unless common sense was absent. The vast majority of the bolt wouldn't be affected. Especially if water was used to prevent the heat build up in the first place.
Honestly, Cab, this isn't that hard or risky.
And if prefer softer bolts, just buy Grade 5 rather than 8. Of course, you don't have that choice with ARP.
On 440 Source, 6 crank to flex plate bolts are about $19 plus shipping. If you need 8,that would be over $5 a bolt. Five dollars would buy just about all 8 at your local hardware store. In either Grade 8 or 5.
Just putting all choices into perspective.
[Re: Gabby63]
#3158038
07/08/23 02:46 PM
07/08/23 02:46 PM
Posts: 19,615 north of coder
moparx
Moparx , When I built my new combo I wanted to use ARP on flexplate , so I bought ARP , for whatever reason they only came in 6pc packages . Yep , had to buy 2 to get the job done with a couple extra in the box . No wonder they are expensive , you need to buy more than you need . Gary
PS:They do work without issues . i know exactly what you mean, as i did the same thing. as i haven't put this combo together yet, i was wondering if there would be any issues with the ARP bolts. thanks for the info. just one more thing i don't have to worry about.
[Re: Diplomat360]
#3159893
07/16/23 09:52 AM
07/16/23 09:52 AM
Diplomat360
Windsor, ON, Canada
So here are a couple more pics that (at least for this particular bolt I checked - and I did NOT check all six of them) clearly indicate there is plenty of clearance between the crank-to-flexplate bolt and the face of the converter. The white sheet is a folder piece of paper stuck between the head of the bolt and the converter body. The 2nd picture shows a much thicker cardboard sheet that still fits quite fine.
Alright, so having said that all I came to discover that as I tightened the remaining motor-to-transmission case bolts, the clearance did actually end up pulling in, which is not something I anticipated, and let me explain what I mean by that.
The initial checks were done with the FOUR top bolts (small block) fully seated. However, as this appeared to be an issue and as I troubleshooted further I noticed that at the very edges where the locating dowels are there was still a bit of clearance, maybe 0.010"??? (I did not measure)
Subsequently once I added the two edge bolts and fully tighteneded ALL of them, it now appeared to almost completely close out the gap I had originally found. Mind you, it was not completely gone, but I would say down to about 0.025" (which I tried to measure with my gap blades, not quite handy getting one in there, but that's the closest I came to getting a good check).
Therefore - and this may be obvious to all of you who have done this countless times - the lesson I learned here is that ALL the engine-to-transmission case bolts must all be installed before anything else can be checked!
Honestly I feel a bit like an idiot to have missed this (I think this was a 'miss'). Thanks everyone for the feedback and troublshooting suggestions though as this allowed me to work through the issue!
Now off I got to fire-up the motor...keeping my fingers crossed we do not get rained out like yesterday!!!
