Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #2132568
08/14/16 10:49 AM
08/14/16 10:49 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Man what some great advice on these posts
Awesome - Thanx guys
What is the proper way to re install the harmonic balancer ??? Pull into back on the crank
I used a steering wheel puller to take it off , worked slick
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: bee1971] #2132620
08/14/16 12:16 PM
08/14/16 12:16 PM
moparx Offline
moparx  Offline
a damper installation tool threads into the crank snout threads, then a nut and washer is used to pull the damper home. this keeps from pulling or messing up the crank threads out of the end of the crank. a tool for this can be bought or fabbed up if you have the means to do so.
beer
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: Mosin] #2138488
08/22/16 11:20 AM
08/22/16 11:20 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Perfection !!!
Once I got the 45 year old timing chain cover all cleaned up , gasket off , bead blasted and paint removed , it was obvious
Passenger side locater pin hole on cover was bent out
That locater hole was protruded out like it grabbed the pin on block and didn't set proper or I had to pound it on many many years ago when I replaced a wiped out cam on a newly rebuilt motor from what I can remember.
Man that was a long time ago
Anyways over time , especially as of late , leak got progressively worse and kept following the profile of the passenger side oil pan gaskets making it look like it was leaking everywhere
Smoothed out the cover , made sure both locater pins where paint free , cleaned up the holes just slightly with a drill bit like mentioned THANX !
Greg At Superformance supplied all my gaskets and seals
Awesome Customer Service !!!
Installed the timing chain cover dry like he mentioned , gasket is a little thicker then your typical fel pro
Superformance oil pan gaskets
Not a drip - Gotta love a leak free motor after a few rides
Just disappointed in myself assuming it was the oil pan gaskets all this time - Yes I had to replace the rear main seal - I wanted to replace the beat up factory 402 oil pan anyways , but wasn't planning on pulling it three times - Was about to buy a reproduction timing chain cover , however the original one ended up looking brand new when all fixed and cleaned up
THANX GUYS !!!
Siberian Huskies
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: bee1971] #2138507
08/22/16 11:47 AM
08/22/16 11:47 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for the update and glad you nailed it up beer
Re: Oil pan gasket and/or timing cover leak? (440-3) [Re: bee1971] #2138749
08/22/16 05:08 PM
08/22/16 05:08 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
bee1971 it was great talking with you as well smile
Glad you found the culprit of your leak.
BTW that's how a motor should look and stay looking! Very nice!
Here's my junk puke
10931530_581145788687970_3629502089197502732_n.jpgCharger Quaker City 2014.jpg
