Re: E-body: What years & engine combo had rear Sway Bar [Re: gtx6970] #3156753
07/03/23 10:58 PM
07/03/23 10:58 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Originally Posted by gtx6970
Originally Posted by Sunroofcuda
Found some more photos: (looks like the Dana cars had a different bar for sure)
Im pretty sure the only cars with a Dana that were avail with rear bars were 71-72 B bodies ( I've seen a couple, and it's a completely different style bar and mounting compared to an E body )
I've never seen a 71 B-Body with a rear bar, so I'm going to state that the '72's were the only Dana cars that ever got a rear sway bar. And correct me if I'm wrong, but I don't think there were any 4-speed 440 cars built in '73-4. How about a '73 Charger Rallye or GTX Roadrunner with a 400 Magnum & 4-speed? Was it available? If so, did it get an 8-3/4 rear?
Re: E-body: What years & engine combo had rear Sway Bar [Re: 6bblgt] #3156768
07/04/23 12:07 AM
07/04/23 12:07 AM
The Garden State
LimelightCuda Offline
The Garden State
Originally Posted by 6bblgt
Originally Posted by LimelightCuda
Both of my E bodies have the rear sway bar. One is a 1970 Barracuda Gran Coupe that originally had a 318-2BBL and the other one is a 1970 A66 Challenger convertible. I know the history of the Challenger since it was bought new and it is untouched since 1984, The sway bar looks very original. According to the fender tag it appears the A66 Challengers got the rear sway bar. Part of the package was "Rallye suspension." The sway bar looks very original on the Barracuda too but unfortunately I just decoded the fender tag and it doesn't say anything about it coming from the factory with a rear sway bar. I think the rear sway bar really helps these car drive and handle a lot better. I like my cars to be mostly original but no way I am taking off the rear sway bar.
I bet they were both built after A53 production - what are their SPDs?
S13 was an orderable OPTION on a 318 car & was required with F70-14 tires on a 318 car
The Barracuda was an early car scheduled to be built October 15th, 1969 and the Challenger was a late car that was scheduled to be built on June 1st, 1970. Neither car has the S13 code on the fender tag. I decoded both cars on ebodies.org. They have a webpage where you put in what the fender tag or broadcast sheet says and it decodes everything for you. You can find that here:
https://www.e-bodies.org/mopar-fender-tag-decoder-build-sheet-vin/
Forgive my ignorance but what is A53 production?
Phil
1970 A66 Challenger Convertible
Re: E-body: What years & engine combo had rear Sway Bar [Re: LimelightCuda] #3156773
07/04/23 01:09 AM
07/04/23 01:09 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
My 1970 340 Cuda, Automatic, has a factory rear sway bar.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: E-body: What years & engine combo had rear Sway Bar [Re: Sunroofcuda] #3156797
07/04/23 08:46 AM
07/04/23 08:46 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The only 71 B with a rear sway bar that I've seen is this 71 Satellite LAPD N code car.
72 was the first year for passenger car B body rear sway bar and yes the 72 B body Dana is the only Dana with a sway bar. as far as I know. The Dana sway and the 71 8.75 has a dip in the center and the 72 8.75 bar that I have is straight across the center. .
We've had 3 Dana E bodies and none had a rear sway bar.
Also as you can see the E and B bodies rear sway bar setups are totally different.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: E-body: What years & engine combo had rear Sway Bar [Re: LimelightCuda] #3156964
07/04/23 04:36 PM
07/04/23 04:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A53 = "TRANS AM" package & S13 would not be coded on a fender tag
the rear sway bar did not exist in October 1969 - it was added to the Barracuda after the factory build
Re: E-body: What years & engine combo had rear Sway Bar [Re: 6bblgt] #3157121
07/05/23 09:06 AM
07/05/23 09:06 AM
The Garden State
The Garden State
Thanks for the information 6bblgt. Dang! After seeing BigDaddys440 fender tag I was hoping the rear sway bar was original. Oh well, I am still keeping it though. Whoever put it on used all factory parts.
Just curious but why isn't the S13 code on the fender tag for my A66 Challenger? Was it included with the "Rallye Suspension" package?
Phil
Re: E-body: What years & engine combo had rear Sway Bar [Re: LimelightCuda] #3157894
07/07/23 08:52 PM
07/07/23 08:52 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I have a 70 model A66 Challenger that I have owned since 1979. It has a factory rear bar. The VIN on the car places it in the middle of T/A-AAR production according to info from Alaskan T/A.
Re: E-body: What years & engine combo had rear Sway Bar [Re: JDMopar] #3158342
07/09/23 07:31 PM
07/09/23 07:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Friend just bought a survivor-ish 1970 N-Code 'Cuda. Los Angeles built car.
No rear sway bar ever.
No holes for frame brackets, U-bolts never apart that sandwiches the sway bar plate that's not there
SPD of 106 (Jan 6, 1970)
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
