Re: hemi oil pan ?
[Re: JohnRR]
#315550
05/12/09 12:56 PM
05/12/09 12:56 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
I think Mancini sells an inexpensive hemi pan and it may not be the same and an original?
I'm almost positive Mancini sells the only "hemi"-style pan of which is patterned after the '70/'71.. The '66/'67 are different than the '68/'69 which in turn, are different than the '70/'71... Whew !!!!
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: hemi oil pan ?
[Re: hemi68charger]
#315551
05/12/09 03:15 PM
05/12/09 03:15 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
I just looked they have an MP hemi pan and their own label hemi pan , both have the same description , $26 price difference , both show 6qt .
Re: hemi oil pan ?
[Re: JohnRR]
#315553
05/12/09 07:39 PM
05/12/09 07:39 PM
Posts: 160 connecticut
69charger R/T
connecticut
Did you put oil in the filter? The dipstick is not different for the hemi pan on a big block.
No I didn't put oil in the filter. I have 5 qts in the motor now, I did run the motor shut in down and then checked the oil, and its right on the full mark. From what I understand the hemi pan holds 6 qts plus the filter,witch should be a total of 7qts. Also from what I understand no one makes a dipstick that will read correctly, so I have to make a new full mark on my dipstick. Is there anyone out there that had to do the same thing when they installed the hemi oil pan on a 440 ??
Re: hemi oil pan ?
[Re: frank]
#315557
05/12/09 10:15 PM
05/12/09 10:15 PM
sixbbl69
I talked to the Mancini guys at MATS about their six quart "hemi" pan. I was told by the Mancini guy total oil capacity would be six quarts using the hemi pan. Not six in the pan and one in the filter, but six total
that should be easy to figure out just ask someone on here who has a 70 up hemi how much oil it holds.
Re: hemi oil pan ?
[Re: ahy]
#315558
05/13/09 07:53 AM
05/13/09 07:53 AM
Posts: 4,799 ILL
MLR426
ILL
The Hemi pan is "supposed" to hold 6 quarts but the oil level is pretty high. I think 5 or 5 1/2 plus one for the filter is more realistic.
I agree. I put in 5 1/2
logan426
Re: hemi oil pan ?
[Re: frank]
#315560
05/13/09 09:57 AM
05/13/09 09:57 AM
JohnRR
U.S.S.A.
I would have to agree with this , I don't think the original pan was a 7qt total system , I have 2 original pans and they are the same depth as the repop , though I don't have a Mancini repop mine are MP , well at least one is , I think I got the other from Hoover's .
As far as the dipstick being off , what dipstick do you have 69 ? Also you need to let the motor sit for a while before checking the oil as it doesn't all fall directly back into the pan , especially with a mopar windage tray .
Re: hemi oil pan ?
[Re: sixbbl69]
#315561
05/13/09 09:58 AM
05/13/09 09:58 AM
JohnRR
U.S.S.A.
so nobody has a 70 up hemi with original dip stick that can tell us how much oil it takes to fill it other than guess what it takes??????????
Why don't you just post the info if you have it instead of acting like a 12 yr old
Re: hemi oil pan ?
[Re: JohnRR]
#315562
05/13/09 02:28 PM
05/13/09 02:28 PM
sixbbl69
i don't know. i know what mancini said when i got my pan and was waiting to see what a real hemi guy says he uses so that leaves you out.don't you have a bicycle to play with little boy?
Re: hemi oil pan ?
[Re: JohnRR]
#315564
05/13/09 02:59 PM
05/13/09 02:59 PM
sixbbl69
just the answer I expected DB
Re: hemi oil pan ?
[Re: ahy]
#315567
05/13/09 10:59 PM
05/13/09 10:59 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The Larger Hemi pickup will suck the pan dry, that is why the larger pans on Hemi. I would agree on the 5 1/2 qts or 6 total quarts in the factory pans.. Since the original motors burned a quart of oil every 1500-2000 miles, they were normally not full anyway.
