Re: 2006 300C SRT8 no start...brake switch? [Re: moparx] #3155332
06/29/23 06:04 PM
06/29/23 06:04 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Originally Posted by moparx
,,, if i were to replace one flex line [on any vehicle] i would replace them all, ,,,
Even on a car whose sole purpose is to give up its engine for another project? wink
If indeed it is the brake line causing it not to start I will likely just clamp it off to allow the system to build pressure. Again, I just want to hear this engine run before investing time/money/effort into it.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 2006 300C SRT8 no start...brake switch? [Re: Cheeto] #3155351
06/29/23 06:58 PM
06/29/23 06:58 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I don't think that brake line pressure is the problem.
It's a wiring problem, but without actually working on the car themselves it's tough for people to tell you where the problem iles.
With it being wrecked there are so many places that there could be wiring damage.
It's just like any other old Mopar, it there is power at the starter (large hot lead) you should be able to feed power to the starter solenoid connection on the starter to make it crank over.
Whether it would actually start with the key in the on position is a whole other story.
Re: 2006 300C SRT8 no start...brake switch? [Re: Cheeto] #3155410
06/29/23 08:55 PM
06/29/23 08:55 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bad neutral or park indicator switch, maybe it thinks it's in gear?
Re: 2006 300C SRT8 no start...brake switch? [Re: SNK-EYZ] #3155415
06/29/23 09:29 PM
06/29/23 09:29 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
I was basing that off of previous advice but he hasn't followed up. shruggy
Completely agree. That's why I'm open to all suggestions.
Again, I agree but everything else seems to work...well the broken headlights don't. grin
When I get more time to truly get after it I'll check voltage at the starter and try jumping the solenoid.
The shift indicator in the dash moves according to shifter position. Is there more than one sensor involved there?
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 2006 300C SRT8 no start...brake switch? [Re: Cheeto] #3155420
06/29/23 09:48 PM
06/29/23 09:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
Have you tried to start it in neutral ? Or just for grins in drive or all of the positions? Here is the neutral switch:
Re: 2006 300C SRT8 no start...brake switch? [Re: A12] #3155446
06/29/23 11:33 PM
06/29/23 11:33 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
90% certain I tried it in neutral. I'll add "try all gears" to the list for when I get back to it. Thank you.
Is that switch mounted on the trans or the shifter?
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 2006 300C SRT8 no start...brake switch? [Re: Cheeto] #3155477
06/30/23 06:41 AM
06/30/23 06:41 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
switch is inside the trans.
Re: 2006 300C SRT8 no start...brake switch? [Re: Cheeto] #3155551
06/30/23 12:50 PM
06/30/23 12:50 PM
moparx Offline
moparx  Offline
sorry Cheeto...........
i forgot you are just trying to get this engine to run, then transplant.
them dang spiders............... panic laugh2
beer
Re: 2006 300C SRT8 no start...brake switch? [Re: moparx] #3155744
06/30/23 10:02 PM
06/30/23 10:02 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
beer
No worries, I had to go back and make sure I even said that way back in the beginning. scope
Excellent advice in a different scenario though. up
Cheeto
It's not perfect.
It's not correct.
It's not yours!
