Page 6 of 7 1 2 3 4 5 6 7
Re: Cooling issue [Re: PhillyRag] #3153449
06/21/23 10:12 PM
06/21/23 10:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by PhillyRag
Quote
how about using an infrared heat gun to check the top and bottom of the radiator, as well as the heater hoses, to get some idea of how hot the engine is actually getting ?
"Correcto"
Folks will spent $hundreds on cooling system parts to fix heating issues,
But don't have, or use, an infrared temp gun.
Being so cheap these days, they should be as common as an adjustable wrench.
Best "tool" to have when questioning accuracy of gauge, digital or analog.
The IR guns are good for an indicator but not always accurate unless calibrated to the surface they are reading. Better yet use a thermocouple and know for sure, Most cheap DVM's come with them wink
Re: Cooling issue [Re: PhillyRag] #3153484
06/22/23 05:12 AM
06/22/23 05:12 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
"Correcto"
03/21/23 02:36 PM
Quote
If this were my issue I would get out the infrared temperature gun and find where the overly hot or overly cool areas are. A few years ago I had my '68 RR overheat and puke coolant only when I parked it and it heat soaked. Thought the 26" radiator was good and could see good coolant flow looking in the cap opening, had a new water pump and thermostat, good fan shroud, the right pulleys and everything in order. Pulled into my good friend's driveway and sat there for a few minutes and started puking coolant. He went to his toolbox and pulled out the infrared thermometer and the lower 2/3rds of the passenger's side of the radiator was stone cold as it was plugged. I couldn't believe it. Re-cored it and no issues even with a cammed engine and A/C. Get the infrared temperature gun out and start checking where your issue might be.
Mike
Re: Cooling issue [Re: A12] #3153487
06/22/23 06:23 AM
06/22/23 06:23 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
so
Re: Cooling issue [Re: TJP] #3153490
06/22/23 07:01 AM
06/22/23 07:01 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Quote
"Correcto"
I agree.
The old $99 top of line Sears Craftsman Infrared units had the added plug to compare its reading to thermocouples, and could adjust the ‘emissivity”.
similar to this unit:
https://www.amazon.com/Thermometer-...NXJFF8/ref=psdc_9931459011_t2_B00EXYPVG2
The way all things digital are declining in price I hope our low end cell phones will soon have thermographic ‘pit viper vision’ display at no added cost.
Even troubleshooting electrical devices it is useful to have “pit viper vision”.
Re: Cooling issue [Re: JohnRR] #3153537
06/22/23 11:01 AM
06/22/23 11:01 AM
Minn
SportF Offline
SportF  Offline
Minn
Originally Posted by JohnRR
Originally Posted by terzmo
I'm starting with a high flow water pump..The 3 row alum rad is fairly new and restrictions/clogs are not an issue..it cools nicely down the road. I also will work on the shroud and seal any air gaps between it and rad. I also "may" remove the stat so there is nothing to restrict the flow and "IF" it cools I'll reinstall it to see if it makes a difference.
If you remove the stat you need to put a restrictor in it's place, water full flowing thru the block/heads is not going to do what it is supposed to do ... transfer the heat from the iron as efficiently as possible.
Personally it's a test that is wasting your time and effort as you aren't going to leave it that way.
Quote
Car will not stay cool while in traffic for a reasonable amount of time.
Describe what you consider a reasonable amount of time is please ...
Let me try this again. We all agree you can't have too much air flow, BUT, some think you can have too much coolant flow? Not so, just a bad rumor that will NEVER go away.
Re: Cooling issue [Re: SportF] #3153543
06/22/23 11:58 AM
06/22/23 11:58 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
X
Re: Cooling issue [Re: NITROUSN] #3153576
06/22/23 02:29 PM
06/22/23 02:29 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
so
Re: Cooling issue [Re: terzmo] #3153598
06/22/23 03:50 PM
06/22/23 03:50 PM
Minn
SportF Offline
SportF  Offline
Minn
[i]
"Really. To much or fast flow rate may not give the radiator the time it needs to do its job. Thats not a rumor]" See, this is why it will never go away. The University of Minnesota has been the premier leader in the engineering of heat transfer since 1884.
No one in the study of heat transfer there at the U of M would agree with you. Either they are wrong, or the physics in your radiator are different than other places in the universe. I can't help but be sarcastic, as this has come up too many times. Think about it.....you can't have too much air flow, but you can have too much fluid flow??? I'm going with what they teach in engineering school.
Now, someone will come up with a story on how this guy did this or that and it proves I'm wrong. No, something else is going on in all of those cases as nobody gets to defy the laws of physics....anywhere in the universe. Good luck with the heat issue.
Re: Cooling issue [Re: SportF] #3153600
06/22/23 04:01 PM
06/22/23 04:01 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Originally Posted by SportF
[i]
so
Re: Cooling issue [Re: SportF] #3153636
06/22/23 06:23 PM
06/22/23 06:23 PM
N
N
X
Re: Cooling issue [Re: NITROUSN] #3153678
06/22/23 09:05 PM
06/22/23 09:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
[i]
Faster is not better when it comes to engine coolant flow rate. The purpose of a radiator is to support heat transfer, which is a time-dependent process. As Flex-a-Lite explains, to move the heat from one medium to another (engine to coolant to radiator to atmosphere), the coolant has to remain in contact with a surface for heat transfer to take place. Moving fluid too quickly through an area can result in laminar flow, where the fluid forms layers. The layer closest to the surface moves slower than layers farther away from the surface. When this occurs, the layers act as insulators and the capacity to transfer heat is diminished.
Re: Cooling issue [Re: A12] #3153681
06/22/23 09:20 PM
06/22/23 09:20 PM
Minn
SportF Offline
SportF  Offline
Minn
You last line there is perfect, and is exactly what happens when the fluid moves slowly.
But, it doesn't matter, no one ever wins an argument even in the face of facts. Have a good day.
Re: Cooling issue [Re: SportF] #3153693
06/22/23 10:13 PM
06/22/23 10:13 PM
N
N
X
Re: Cooling issue [Re: terzmo] #3153733
06/23/23 07:24 AM
06/23/23 07:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
[i]
All I can tell anyone is the test ride last night in 82 degree heat and stuck in traffic the temp never hit 190. Before this I would of been forced to shut down on the side of the road as getting stuck in traffic and inching a few feet...stop..idle for minutes and repeat would drive the temp past 200 and climbing. I switched to a half inch shorter diameter pulley (now the pumps going to run faster, and installed a high volume water pump. . Now the water flow is even faster. That's it in a nutshell. You can give this feedback to the University if You care to.
As a side note....engineers designed cars since day one. The cars made in the past 30 years or so should be worked on by these "engineers" as they have designed vehicles that are are real PITA to work on or impossible for a backyard mechanic who works them as a hobby.
I wonder if what you are seeing is because the fluid is not flowing slow enough to extract the heat? It would be interesting to see a comparison of AFR and EGT numbers as it was vs. how it is now ...
Re: Cooling issue [Re: JohnRR] #3153781
06/23/23 10:06 AM
06/23/23 10:06 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
so
Re: Cooling issue [Re: NITROUSN] #3153828
06/23/23 01:19 PM
06/23/23 01:19 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Faster is not better when it comes to engine coolant flow rate. The purpose of a radiator is to support heat transfer, which is a time-dependent process. As Flex-a-Lite explains, to move the heat from one medium to another (engine to coolant to radiator to atmosphere), the coolant has to remain in contact with a surface for heat transfer to take place. Moving fluid too quickly through an area can result in laminar flow, where the fluid forms layers. The layer closest to the surface moves slower than layers farther away from the surface. When this occurs, the layers act as insulators and the capacity to transfer heat is diminished. [/quote]
That is so wrong, if Flexalite says that I am glad I didn't buy their stuff. If you actually bothered to look up any heat transfer formulas you will see that time is not directly in the calculation but rather is expressed in the rate of flow (I.e. GPM) and in the calculations each increase in the rate of flow increases the rate of heat transfer. It matters not if it's the coolant or the air flow rates being considered.
I mean nobody suggests you turn the cooling fan slower so that the air "has time to transfer the heat". But if your supposition were true, it isn't, then it would stand to reason that slower airflow would help, it doesn't.
And there is no laminar flow in the cooling system EXCEPT in slow flow situations and in the radiator tubes. https://en.wikipedia.org/wiki/Laminar_flow
Re: Cooling issue [Re: Sniper] #3153840
06/23/23 01:51 PM
06/23/23 01:51 PM
N
N
X
Re: Cooling issue [Re: NITROUSN] #3153855
06/23/23 02:53 PM
06/23/23 02:53 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
[quote=NITROUSN]
X
[Last edited by NITROUSN; 06/23/23 02:04 PM/quote]
Totally agree, not worth the argument up wink
Re: Cooling issue [Re: A12] #3153857
06/23/23 03:08 PM
06/23/23 03:08 PM
N
N
Originally Posted by A12
[quote=NITROUSN]
X
up up up
Re: Cooling issue [Re: Sniper] #3153886
06/23/23 06:02 PM
06/23/23 06:02 PM
Minn
SportF Offline
SportF  Offline
Minn
OK, the U of M must be wrong, I'll get a hold of engineering and tell them they've been doing it all wrong and that they must have missed a decimal point in their studies years ago. Mean while the heat goes on!
