Re: Anyone running a Holley Sniper EFI on an Edelbrock RPM? [Re: skdmark] #3152769
06/19/23 06:03 PM
06/19/23 06:03 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Originally Posted by skdmark
Originally Posted by Sniper
[quote=skdmark]I'm running a sniper on a ld4b intake with a 1 inch phenolic spacer. It's worked really well.
The phenolic spacer also acts as an insulator.
Why would you need an insulator? It's a return system.
Insulate the ECU in the sniper from heat transfer. [/quot
Good point. The only thing I don’t like about the Snlper TB EFI is the ECU is in the throttle body. Wish they made it like the Atomic and FAST EFI with the ECU module separate, so it could be mounted inside the vehicle away from the heat.
Re: Anyone running a Holley Sniper EFI on an Edelbrock RPM? [Re: Dabee] #3152861
06/19/23 10:07 PM
06/19/23 10:07 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Terminator Stealth
https://www.holley.com/brands/holle...ction/terminator_efi/terminator_stealth/
Re: Anyone running a Holley Sniper EFI on an Edelbrock RPM? [Re: RTSE4ME] #3152887
06/19/23 11:28 PM
06/19/23 11:28 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Terminator Stealth
Terminator Stealth is a different efi than the sniper 550 systems. Comparing apples to oranges. Sniper cost is in $1200 range. Terminator Stealth is $3,300 range.
Re: Anyone running a Holley Sniper EFI on an Edelbrock RPM? [Re: Dabee] #3152947
06/20/23 09:27 AM
06/20/23 09:27 AM
MD
MD
I paid around $1400 for mine from fastmanefi. For a couple hundred dollars more you get a better ecu. Buy a $60 cable lets you tune or just drive it. I guess a bit less wiring involved with Sniper.
https://www.summitracing.com/parts/...bYP_WgqKVrj7jgqIlS4JAOD_eBwaAroAEALw_wcB
