Page 10 of 17 1 2 8 9 10 11 12 16 17
Re: Slow Progress at Zippy Performance [Re: tboomer] #3137359
04/12/23 12:38 PM
04/12/23 12:38 PM
Chicago-area Illinois
4mopower Offline
4mopower  Offline
I second that!
Re: Slow Progress at Zippy Performance [Re: 4mopower] #3137384
04/12/23 01:58 PM
04/12/23 01:58 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Rich, i can't remember, but are you putting the side trim, and lower black back on the car? That color combo would look good with the red reflective stripe.
69 GTX 68 Road Runner
Re: Slow Progress at Zippy Performance [Re: JERICOGTX] #3137399
04/12/23 02:52 PM
04/12/23 02:52 PM
S.E. Michigan
ZIPPY Online content OP
ZIPPY  Online Content OP
S.E. Michigan
Side trim delete. A not so Rare option wink
For years I always said I’d put the trim on if I had it, but the car
Never had it during my ownership, and I never acquired it.
after replacing all the metal I’m not sure I’d have the
Heart to drill 40 holes for that trim.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3138711
04/17/23 12:16 PM
04/17/23 12:16 PM
S.E. Michigan
S.E. Michigan
Did some more stuff.
Was totally clueless how to install the trunk torsion bars/seemed counterintuitive. Once I understood how, it took about 5 minutes.
The service manual confirmed my improvised approach was more or less backwards. I've never messed with those before, ever and hopefully
never will again.
On disassembly, you could see the factory assembled the metal, greased the trunk hinges, and then painted right over the grease.
As awesome as a factory original car might be, I didn't do that....
Now that everything has new slippery paint on it, it all needs to be adjusted and seems to be fighting me.
I used to be able to just wiggle the pieces around a little, and they'd find their old home in the very few places there wasn't any rust. Not anymore.
Alot of prep I did 2 years ago on tedious little things (rebuild/clean/epoxy most of the hinges and things like that), paid off....as I could clean/prep/paint them real quick now.
I did mess up by waiting to rebuild the upper door hinges until now, so that slowed me down a couple hours or whatever but nothing too bad.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3138713
04/17/23 12:20 PM
04/17/23 12:20 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice progress!
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3138715
04/17/23 12:22 PM
04/17/23 12:22 PM
S.E. Michigan
S.E. Michigan
Floor jacks and muscle power, turned the car sideways for final prep.
Washed the floor for the first time since last fall. It's still not actually clean, but it's better.
The biggest problem is not only my bodywork project, but one of the rams in my hoist sprung a dang leak. The hoist works fine but you go through alot of oil-dri.
So that is first on my list to repair once this has color on it and is curing. If anyone local knows someone good I can just drop the cylinder off to... to be rebuilt,
pls let me know about them as I'd gladly go that route.
The hoist + high lift garage door tracks will make good attachment points, and I shouldn't need to add a ton of structure to section the car off
with plastic or whatnot to control the airflow/protect everything that I don't want painted.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3138720
04/17/23 12:32 PM
04/17/23 12:32 PM
S.E. Michigan
S.E. Michigan
The view when I open the door:
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3138761
04/17/23 02:56 PM
04/17/23 02:56 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
WOW....looks like its almost that primer time ! ! !
GO ! GO ! GO !
....BAD A$$ STREET CAR.....
Re: Slow Progress at Zippy Performance [Re: n20mstr] #3138764
04/17/23 03:02 PM
04/17/23 03:02 PM
moparx Online content
moparx  Online Content
your car will look AMAZING when done ! bow bow
keep after it. won't be long now ! up boogie
beer
Re: Slow Progress at Zippy Performance [Re: moparx] #3139794
04/21/23 04:59 PM
04/21/23 04:59 PM
S.E. Michigan
S.E. Michigan
Change of plans I probably communicated on another platform but not here....Enough grinding and welding needs to happen in the engine bay
that I think I'll not do that until later.
So I will leave the Wedge in it to get the exterior done.
then after engine comes out repairs/changes happen in the engine compartment, the color will match.
Getting ready to bolt the fenders on pretty soon and had to get my topcoat in all the back areas.
These are still curing and I think I achieved the target of "Pretty close to factory appearing, but cleaner" look that I was after with the seam sealer application.
High K factor camera flash as shown here=Medium, very normal looking Silver.....Low K factor=flop to green or gold.
The color is like a "mood ring" (remember?) I love it.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3139797
04/21/23 05:35 PM
04/21/23 05:35 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Rich,
Damn! Looking good brother! Nice work!!!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Slow Progress at Zippy Performance [Re: EvilB1Dart] #3145320
05/18/23 12:49 PM
05/18/23 12:49 PM
S.E. Michigan
S.E. Michigan
Needed to go one step backward on the trunk lid to get it the same level as the rest of the body.
That one part has been quite alot more work than it should have been.
If I could go back in time, I'd have used polyester primer on it which would have helped me get it right, faster.
Lesson learned.
It's almost all blocked out to P320 except below the character line on the right side, which I should get done over the next couple days.
Above the character line all the cut throughs to metal and underlying layers of epoxy have been addressed with fresh epoxy and more 2k urethane surfacer, to give the final P600 something to work with.
That can all sit there, outgas and shrink for awhile.
Will need to do the same to the lower body areas as well.
Still need to address lower grille support, have not done anything yet and will probably prep my original part.
I already look at it, even like this, and can't hardly believe it's mine.
It's looked like hot garbage for over a decade now and I both hated it and was adjusted to it at the same time.
It's probably going to feel a little strange to not be able to throw wrenches at it anymore like I used to, and to have to cover the fenders with blankets and stuff when working on it.
I'm looking forward to the change, though.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3145412
05/18/23 08:38 PM
05/18/23 08:38 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
It's going to look amazing when you are done. up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Slow Progress at Zippy Performance [Re: DynoDave] #3145622
05/19/23 05:16 PM
05/19/23 05:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd love to see it. There is something to be said about not being careful with wrenches. I loved working on Dizusters car for that fact. The 64 has been raced for 10 years. Lots of valve lash checks, engine work, and tuning. It still looks pretty damn good. Very few rashes to the paint.
Doug
Re: Slow Progress at Zippy Performance [Re: dvw] #3146357
05/23/23 10:59 AM
05/23/23 10:59 AM
S.E. Michigan
S.E. Michigan
Hope to invite a few known cool local folks over once I have something a little more worthy of inspection, and a slightly more presentation-ready shop.
Might be a minute!! wink I'm going to keep messing it up and only cleaning the localized important areas for awhile yet.
About an hour with paint stripper and a half hour with the sandblaster proved I can save the OE lower grille support.
You never know what you have until all the coatings and fillers are removed.
I'd bought a reproduction and it's pretty nice but I liked the OE one a little better.
It might be the original part it was built with but I don't know...It came on the car back in '88 when I acquired it, and doesn't look to have been changed, but it may have been
swapped decades ago with the original right front fender was mashed and replaced. I can't tell, I'm not that good.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3151476
06/14/23 01:01 PM
06/14/23 01:01 PM
S.E. Michigan
S.E. Michigan
A couple finish sanding pics
+ wet check of the trunk lid, (by far the worst panel on the vehicle, now maybe not so anymore)
+ a reminder of something already produced, that I just need to duplicate on the exterior (Knowing for sure
You can already do what you’re trying to do, and having proof, helps alot ).
I’ll be chasing and refining scratches for quite awhile yet.
Wet check shows the car is pretty straight for an amateur, and I just have to refine the surface
properly, keep it clean so I can see what I’m doing, and end up with a uniform p600 prepped surface.
From test panels, I know what happens when you miss a scratch (metallic lays in it, looks bad) and can’t allow that to happen.
IMG_2023-6-14-121611.jpegIMG_2023-6-14-121802.pngIMG_2023-6-14-122302.pngIMG_2023-6-14-122400.png
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3151514
06/14/23 03:02 PM
06/14/23 03:02 PM
i see a small dent !!! eek
just yankin' yer chain ! laugh2
everything is looking great ! keep up the good work ! up
beer
Re: Slow Progress at Zippy Performance [Re: moparx] #3151519
06/14/23 03:21 PM
06/14/23 03:21 PM
S.E. Michigan
S.E. Michigan
LOL!
I'm busted! You've got a great eye!
I knowingly did let two dents go, that one you can see on the inside of the decklid, and there is also one other that is also hidden when the decklid is closed.
I've gotta draw the line somewhere, the goal is still the same.... "really nice looking"...not perfection or even close.
It's fun to be called out on that, thanks smile
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3151784
06/15/23 01:52 PM
06/15/23 01:52 PM
if anyone looked at my charger, they would fall on the floor laughing so hard at all the bad spots ! laugh2
having worked in a body shop and played the auction game, i really appreciate GOOD body work, and you sir, are doing a GREAT job ! bow
i have a friend that has been a body man for over 50 years, and your work rates right up there with his ! up
beer
Re: Slow Progress at Zippy Performance [Re: moparx] #3154134
06/25/23 08:56 AM
06/25/23 08:56 AM
S.E. Michigan
S.E. Michigan
Got about 6 hours of sanding, cleaning, scratch refinement in yesterday.
It’s very close to where I want it now.
Rich H.
Esse Quam Videri
