Re: Aero mods 69 Charger
[Re: HardcoreB]
#3181611
10/06/23 09:45 AM
10/06/23 09:45 AM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Agreed. I really appreciate all of the details and engineering!
[Re: Blusmbl]
#3181635
10/06/23 11:06 AM
10/06/23 11:06 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Thanks guys It will be going to the dragstrip soon. In street trim on the road race tires (so 4270 race weight, 4100 without me). Just installed a 4.56 and ordered a carbon fiber driveshaft so I can raise the rev limiter. DGS I forgot to respond, it's only that close now to get the alignment correct while building it. When done I'll trim it back for more clearance and connect the two with a rubber coupler. (Though there is little movement with the schumacher motor mounts)
[Re: John Brown]
#3185509
10/21/23 02:10 PM
10/21/23 02:10 PM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Those last two pictures deserve a 'like button'. I know a website that has a like button Magnificent work on this car
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: moparx]
#3185598
10/21/23 10:15 PM
10/21/23 10:15 PM
Posts: 9,871 MI, usa
dvw
MI, usa
[Re: INTMD8]
#3185970
10/23/23 04:02 PM
10/23/23 04:02 PM
Posts: 4,700 Wichita
GY3
Wichita
Thanks guys! Getting it ready for paint was more work than I thought. Then of course, as I usually screw up the wrinkle paint, this one is no exception so I'm removing it all to try again. I was happy to cut the top as I didn't like the little plug in the side of it for my non-existent breather hose. (it's just a reproduction) Wrinkle paint on that much surface area is a be-otch to get consistent! I've done air cleaners and it takes some practice to make it look "right".
[Re: GY3]
#3186053
10/23/23 09:31 PM
10/23/23 09:31 PM
Posts: 1,401 Wi.
old_racer
Wi.
[Re: INTMD8]
#3186582
10/26/23 07:31 AM
10/26/23 07:31 AM
Posts: 4,075 Mo.
racerx
Mo.
