Hi,
This is not an item I am associated with, but thought I would post. Maybe Barry has it in his registry.
I saw this on Allpar
Extremely rare AAR ‘Cuda engine, Serial # OB3020_8, block# 3577130.T.A 340.1 including rebuilt T/A heads # 3418815, new .030 over pistons w/ new rings,timing chain, original oil pan with windage tray,new purple stripe cam, forged steel cranks [quantity 2 = original 303.4 ci and 340 ci PN 2843868]. Professionally machined and fitted. If you have an AAR ‘Cuda, or T/A Challenger but need a matching motor, this is it. Make offer
Matching number 727 trans with 3500 rpm stall speed torque converter. Make offer
