Re: stuck throttle!
[Re: Thelma133]
#3149039
06/06/23 04:06 AM
06/06/23 04:06 AM
Posts: 635 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Lucky escape, glad there was no damage and nobody was hurt. Its great that you had the presence of mind in a nano second to hit the switch.....many may not have. Great save. I'm super anal on throttle linkage setup as I've seen a lot of similar things happen. Good job !
Re: stuck throttle!
[Re: LAD 524]
#3149045
06/06/23 05:58 AM
06/06/23 05:58 AM
Posts: 10,150 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Lucky escape, glad there was no damage and nobody was hurt. Its great that you had the presence of mind in a nano second to hit the switch.....many may not have. Great save. I'm super anal on throttle linkage setup as I've seen a lot of similar things happen. Good job ! I say a prayer every time i get in the drivers seat. That is why I believe i got "help" in this misshap. The reaction had to be almost instant to get it shut off. The car moved another 20+ feet after i hit the switch. I don't claim to be that good!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: stuck throttle!
[Re: gregsdart]
#3149058
06/06/23 07:14 AM
06/06/23 07:14 AM
Posts: 730 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
You know, they make a msd ignition tester that will allow you to test all rpm "stuff" without starting the car. MSD tech said no! So please, who do i talk to to get a tester? What was the name of the tech? So everyone can avoid this dunba--. Joe
Without Data, youβre just another guy with an opinion.
Re: stuck throttle!
[Re: HardcoreB]
#3149086
06/06/23 09:22 AM
06/06/23 09:22 AM
gregsdart
GLAD you are ok and there's value in sharing to remind us that these things happen...Now go put up some #'s! Sean, I am going back over the car with a fine tooth comb, after finding a couple issues with front brakes. On top of that, the track I really want to test at is BIR, because of the very long shutdown. plus friday test and tune is eight hours. So another delay. July, third weekend.
Re: stuck throttle!
[Re: FastmOp]
#3149277
06/07/23 05:56 AM
06/07/23 05:56 AM
gregsdart
Always point it out the driveway ππππ© I now have a full awareness of the dangers of testing off track. In the case of my misshap, had i not hit that switch EFFECTIVELY, the odds are i had a good chance of crashing into the garage, getting trapped, and die in the ensuing fire. Not something i want to experience. No more testing without jackstands is the new norm. So I am ordering a morse cable to hook to my current electrical shut off . The cable will go to the shifter area, for instant access to shutting down the power. I had talked before about doing this, but this incident pushes me into action. I hope this incedent prompts others hear to realize that this poo can happen to them, and take appropriate action to protect themselves.
Re: stuck throttle!
[Re: gregsdart]
#3149287
06/07/23 07:12 AM
06/07/23 07:12 AM
Posts: 2,555 PA
moparacer
PA
Yes, I seen people tear up cars and even get killed over the years doing that so if I do need to test my trans brake and 2 step the only place mine gets tested is at the track. I find a spot where the car is pointed away from everyone and everything, like into a field or something and then hit the button, go up against the chip and let off. Throttle controllers like you have are very tricky in that they let the throttle go to an idle, then come back up. You just have to remember to let off the throttle and not the t brake button. I have one on my car too.
Thank goodness you got it stopped.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 5.44-126 414 cid SB Dragster 7.65-174
