Re: Converter stall speed ? 572 B1 heads, PG trans [Re: dvw] #3149305
06/07/23 09:11 AM
06/07/23 09:11 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I looked at other peoples dyno sheets (since my motor was not tested), and a typical horsepower difference for this type of motor is 75 hp between 5400 rpm and 6300 rpm. That is a lot.
Re: Converter stall speed ? 572 B1 heads, PG trans [Re: 440Jim] #3149907
06/09/23 08:20 AM
06/09/23 08:20 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
And how much different is the HP between 5400 and 6900? If you're going to even bother adjusting the converter then consider that the consensus here is to stall higher than 6300 for many reasons.
Re: Converter stall speed ? 572 B1 heads, PG trans [Re: 440Jim] #3150217
06/10/23 11:59 AM
06/10/23 11:59 AM
gregsdart Offline
gregsdart  Offline
bingo! and you have to pull through the first part of both gears before you get to good power. And it makes sense loose would be more consistant, so time to pull and restall the converter, right?
Re: Converter stall speed ? 572 B1 heads, PG trans [Re: 440Jim] #3150352
06/10/23 10:17 PM
06/10/23 10:17 PM
AndyF Offline
AndyF  Offline
Jim, you really need a data logger. Your analytical mind would eat up the output from a data logger.
I spent all day at the track today helping a guy get his 2022 COPO dialed in. It was interesting to watch how the stall speed would change as we would make other adjustments to the car. Not that stall speed changes a huge amount, but we could move it up or down 100 rpm by changing two step RPM or shift RPM.
The other thing that was interesting is that the car ran almost exactly the same times all day along regardless of what we changed. We varied the timing from 34 to 38, adjusted the two step RPM up and down several hundred RPM and we changed the shift points up and down a few hundred RPM. Car kept repeating within 0.01 regardless of what we did.
