Re: Best dash speaker for b body [Re: Cab_Burge] #3149803
06/08/23 07:44 PM
06/08/23 07:44 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Originally Posted by Cab_Burge
I "think" the originals pre 1974 factory single speakers where 4 ohms, maybe 8 ohms. confused
As far as ohm rating the smaller, lower, the numbers the less resistance. I'm not sure about how that affects the wattage needed to drive them confused shruggy
I'm wondering if the stock AM and AM/FM/ and AM/FM tape player radios had different wattage output for multiple stock speakers work confused
Back in the pre-74 days, all of the OE head units had either a mono 4Wx1 output stage or a stereo 4Wx2 output stage, all into 8 Ohms..
As the aftermarket stereo biz grew then next higher powered head units having 10W per channel output having what was called a bridged output stage which was actually dual amplifier stages in a push-pull type circuit...
However the bridged output stage did not use a common chassis ground circuit, all speaker output leads (+ & -) were above ground..
Just my $0.02... wink
Re: Best dash speaker for b body [Re: Sinitro] #3153936
06/24/23 12:24 AM
06/24/23 12:24 AM
Someplace you aren't
SomeCarGuy Offline OP
Got my radio back from Devin Duke and I went with the SM Electrotech speaker. That was where he recommended to look and it worked out awesome. It’s as clear as any new car radio, exactly what I wanted. I’ll put my fm convertor box on after the local concours show I’m in and then I should be golden. Thanks to all who replied.
I want my fair share
