Re: Piston massaging [Re: fast68plymouth] #3147818
05/31/23 01:22 PM
05/31/23 01:22 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted by fast68plymouth
Originally Posted by an8sec70cuda
The pistons may actually be installed "correctly". The arrow pointing "front" does appear to be pointing to the front of the engine, if that's the engine stand I see on the right side of the pic.
Someone modified those L2355 "six pack" pistons by milling a dish in them...they are normally a 4 valve relief design. I've never seen a dish like that on the "top" side of the piston before, that would ruin any quench you may have had. It's possible whoever machined the pistons put the dish on the wrong side of 4 of them.
It really won't hurt anything, just not the normal way of doing it. grin
The pistons can be swapped side to side, which will properly orient the dish and quench areas so there could actually be some benefit when swapping to closed chamber heads.
The arrow would then be pointing towards the rear........ which some claim is beneficial as well.
This ^^^^^
Does that trw piston have an offset pin? It's been decades since I looked at one but i don't think it is offset. I would put them with the dish facing the chamber and call it done.
I don't know what the compression might be without knowing the deck ht. and the volumes of the dish, chamber and head gasket.
Re: Piston massaging [Re: lewtot184] #3147838
05/31/23 02:10 PM
05/31/23 02:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The valve relief depth show the valve stems inclined toward the exhaust side: wrong.
Boffin Emeritus
Re: Piston massaging [Re: polyspheric] #3147840
05/31/23 02:20 PM
05/31/23 02:20 PM
an8sec70cuda Offline
The dish was machined in those pistons after they were bought. When new, those pistons are flattops w/ 4 valve reliefs allowing them to be installed on either bank. You can see the remnants of the other two reliefs on the dished side.
If all 8 pistons had the dish cut the same way, then 4 of them will appear to be installed incorrectly if the directional arrow is pointing to the front.
The other bank may have the dish in the correct orientation.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Piston massaging [Re: Cudatali] #3147849
05/31/23 03:15 PM
05/31/23 03:15 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
One thing to remember is the piston is running away from the intake valve on the intake stroke, and then during the compression stroke some turbulence is good to keep the air fuel mixture mixed up. The reasons for quench pads on pistons and a quench area on closed chambered heads. I guess it must work as I don't know of and aftermarket wedge heads without a quench area in the chamber.
Re: Piston massaging [Re: jwb123] #3147858
05/31/23 04:23 PM
05/31/23 04:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I always soften sharp edges. Smoother is better. Eliminate potential hot spots. Verify the extended tip plug isn't crowded.
Re: Piston massaging [Re: Cudatali] #3147914
05/31/23 10:52 PM
05/31/23 10:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the cam, and especially the overlap window area, is smaller than optimum, radiusing & blending those sharp edges is helpful as it makes flow through the chamber more efficient.
If the cam is too big: leave it along.
Large chamber + low static CR: don't bother.
Boffin Emeritus
Re: Piston massaging [Re: Cudatali] #3147988
06/01/23 01:28 PM
06/01/23 01:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted by Cudatali
[quote=LA360] The plan is to install some aluminum heads, get compression between 9.5-10.0. Install a 22X-23Xish cam and a 6bbl setup. With that being said, Would CR close to 10:1 .
I shoot for between 10.530 to 10.80 to 1 compression ratio on my non ethanol 91/93 octane pump gas BB builds with aluminum heads, that has work very well for me and my customers up work twocents
Thanks for the advice unfortunately I have no access to non ethanol in my area.
Ethanol in the fuel makes the fuel act like it has higher octane than it really does, compression can go higher with ethanol, the only concern could be fuel system corrosion but in nearly 20 years I have never had an issue running old fuel system components even my experiment with a bunch of parts and pieces in a sealed up peanut butter jar has not shown any degradation of the parts. It needs access to the atmosphere for extended periods of time to absorb moisture and that is what causes corrosion.
As for messaging the pistons I always round off all the sharp edges, you never know when you might get a bad batch of fuel or maybe they are out of premium and you got to run low grade in a pinch or the fuel delivery guy acidently put some diesel fuel in the tank in the ground, maybe you decide later on down the road to put some smaller chamber heads on and the work is already done without disassembling the short block or... it is just cheap/free insurance.
