Panhard Bar w/ Ladder Bars #314756
05/11/09 01:57 PM
05/11/09 01:57 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Do any of you have pictures of a panhard bar used with ladder bars?
Re: Panhard Bar w/ Ladder Bars [Re: mopowers] #314757
05/11/09 02:04 PM
05/11/09 02:04 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: Panhard Bar w/ Ladder Bars [Re: QWK_ENUF] #314758
05/11/09 09:57 PM
05/11/09 09:57 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks. That helps.
I've heard it's good to keep the panhard bar parallel to the axle as possible. Whats the best way to do this? 1) Space it down from the framerail, 2) Space it up from the axle tube, os 3) Split the diff and space it equally form both until it's parallel?
Re: Panhard Bar w/ Ladder Bars [Re: mopowers] #314759
05/11/09 11:11 PM
05/11/09 11:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks. That helps.
Thats what I did on my street car with ladder bars,
the panhard bar. Yes you need to try and keep it
parallel, a longer mount from the frame and the axle
with a back brace on both. Now I would run a watts link,
basically its 2 panhard bars 1 on each side that attach
to a cross bar... this holds the rear centered and has
plenty of strength(you can google Watts Link)
Re: Panhard Bar w/ Ladder Bars [Re: MR_P_BODY] #314760
05/12/09 03:24 PM
05/12/09 03:24 PM
New Haven County CT
Mr 5 Speed Offline
Mr 5 Speed  Offline
New Haven County CT
Here is the setup on the Duster
Re: Panhard Bar w/ Ladder Bars [Re: Mr 5 Speed] #314761
05/12/09 09:15 PM
05/12/09 09:15 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I would like to go that route, but I've been told by several people that a diagonal locator is a no-no for a street car. They said it won't let the axle articulate over bumps and entering/exiting parking lots.
Is this true?
BTW, thanks for the info Mike. I researched a watts link. They seem really pricey. Are they absolutely necessary?
Re: Panhard Bar w/ Ladder Bars [Re: mopowers] #314762
05/12/09 09:39 PM
05/12/09 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this true?
Its not the diagonal link that causes that, ladder
bars in itself do that, the bars are both(we will
call it rigid)they cant work independently
The watts link is pricey if you bought it, I would
build it myself
