8 3/4 case? #3146980
05/26/23 08:23 PM
05/26/23 08:23 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Which one do you like? Street use 741 - 742 - 489. Big block 4 speed car probably going to be hard on it. Thanks
Re: 8 3/4 case? [Re: bobs69] #3146990
05/26/23 09:16 PM
05/26/23 09:16 PM
Kirkland, Washington
Pacnorthcuda Offline
742 hands down, no contest. Now if you take a 489 and use a crush sleeve eliminater that’s fine too.
Re: 8 3/4 case? [Re: bobs69] #3146991
05/26/23 09:23 PM
05/26/23 09:23 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I have used all of those cases without a problem. Even the 741, with the supposedly "small" pinion gear is bigger than a Ford nine inch. The factory used them behind some nasty engines and they held up just fine. Unless you're building a 500 horsepower or stronger motor you should be ok. All of the pinion gears are pretty much the same size where the pinion nut sits.
Re: 8 3/4 case? [Re: elmor353] #3147000
05/26/23 10:39 PM
05/26/23 10:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Being a street car all would likely be fine unless you have your suspension really dialed in with sticky back tires. I would then lean towards the 742 or 489 case twocents beer
Re: 8 3/4 case? [Re: TJP] #3147023
05/27/23 07:56 AM
05/27/23 07:56 AM
Minn
SportF Offline
SportF  Offline
Minn
Wouldn't a pinon break at its smallest-weakest point? AND, aren't all the yokes the same.......so what's wrong with a 741? This has been a mystery to me as much as DOT5 Good luck.
Re: 8 3/4 case? [Re: SportF] #3147056
05/27/23 12:49 PM
05/27/23 12:49 PM
moparx Offline
moparx  Offline
i have beat hard on all of the above cases, but since i can's shift a 4 speed for $hit, i'm a wimpy automatic guy. biggrin
beer
Re: 8 3/4 case? [Re: SportF] #3147070
05/27/23 02:35 PM
05/27/23 02:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the pinion stem ends are pretty much the same but most failures occur because of pinion deflection...IOW, under load, the pinion gear tries to deflect from the ring gear and tooth contact is lost leading to tooth failure. A larger pinion stem and bearing resist this deflection...the 742 (on the right below) has the best combination of stem size and bearing size to resist deflection.
Re: 8 3/4 case? [Re: elmor353] #3147091
05/27/23 03:59 PM
05/27/23 03:59 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
There is a reason the factory went with a Dana behind a stick with a "nasty engine".
That said, the 742 survived just fine behind the warm 413/stick combo in my 64 300 with N50's.
Re: 8 3/4 case? [Re: John_Kunkel] #3147121
05/27/23 07:10 PM
05/27/23 07:10 PM
Originally Posted by John_Kunkel
[quote=SportF]Wouldn't a pinon break at its smallest-weakest point? AND, aren't all the yokes the same.......so what's wrong with a 741? ...the 742 (on the right below) has the best combination of stem size and bearing size to resist deflection.
iagree
I've crack, (and had some teeth break off) the outer edge of the ring gear teeth on all three rear ends with a 727 and nine inch slicks whiney down shruggy
Not so on a Dana 60, yet luck
Re: 8 3/4 case? [Re: John_Kunkel] #3147165
05/28/23 07:59 AM
05/28/23 07:59 AM
Minn
SportF Offline
SportF  Offline
Minn
Well, I gotta say that picture clears it up for me. Great comparison, thanks for that. Once again Mr. Kunkel's expertise teaches me something.
Re: 8 3/4 case? [Re: SportF] #3147217
05/28/23 12:15 PM
05/28/23 12:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The credit goes to Dr Diff, the photo was pirated from this article in the tech archives.
There is more to the story also.
Go to the tech archives sometime and start reading. That’s where these guys get lots of this stuff from.
http://www.moparts.org/Tech/Archive/axle/1.html
Re: 8 3/4 case? [Re: SportF] #3147225
05/28/23 12:42 PM
05/28/23 12:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
FIXED VERSION;
Quote
Well, I gotta say that picture clears it up for me. Great comparison, thanks for that. Once again Dr. Diff's expertise teaches me something.
beer
Re: 8 3/4 case? [Re: Alaskan_TA] #3147789
05/31/23 11:41 AM
05/31/23 11:41 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
A serious issue with the 741 is the lack of new gear sets in many different ratios. I have beat on a 741 for years, but if starting from scratch would go 742. Which I eventually did when I went to 4:10
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
