Re: Ring ridge [Re: Cab_Burge] #3147563
05/30/23 10:07 AM
05/30/23 10:07 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Originally Posted by Cab_Burge
i think the 1971 "346" heads where one year only, no on the harden seats as leaded fuel was still being made and sold in 1970, probably until 1976 or maybe even later than that scope
Oops wrong number, 902, thinking one thing writing another.
Re: Ring ridge [Re: cudaman1969] #3147675
05/30/23 07:20 PM
05/30/23 07:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe 73/74 was the change over to unleaded fuel. I suspect harden valve seats came along around mid 72, the manufacturers knew it was coming. The hardened valve seats are inserts, you should be able to see them in the heads.
Re: Ring ridge [Re: poorboy] #3147685
05/30/23 08:00 PM
05/30/23 08:00 PM
A727Tflite Offline
A727Tflite  Offline
Hardened seats from the factory were flame hardened. Not inserts.
Aftermarket used inserts to repair bad seats and to replace standard with hardened seats.
Re: Ring ridge [Re: A727Tflite] #3147702
05/30/23 09:15 PM
05/30/23 09:15 PM
fredericksburg,va
fredericksburg,va
I read today those heads had seat cracking problems, might be time to get the 452 heads off junk pile.
