318 small block ‘X’ block. Give me the dirty little details.
#3146836
05/25/23 08:14 PM
05/25/23 08:14 PM
Posts: 21,077 San Jose,CA
migsBIG
San Jose,CA
So long story short, was told this guy has a TA/AAR block and turns out to be a 1979 dated Mopar Performance over the counter block and has been sitting in his shop since the early 1980’s. Now I know a little something about the ‘R’ blocks produced later on, but nothing on the ‘X’ ones. It looks to have a standard bore set of 340 pistons, but the guy will double check the bores when he gets back home tomorrow. The 4-bolt mains look super beefy and dang, it felt heavy like a 440 block.
So my question is: Are these desirable? How much hp/tq are they good for? Is there a value to owning one or just sell it? Thanks in advance.
Re: 318 small block ‘X’ block. Give me the dirty little details.
[Re: migsBIG]
#3146839
05/25/23 08:40 PM
05/25/23 08:40 PM
Posts: 11,600 Portage,michigan
B3422W5
Portage,michigan
Ultra desirable Come 2 or 4 bolt Come 3.91 bore, have seen them check good for use at 4.125 bore. But each one can be a bit different. So, to get to a standard 4.04 340 bore, need lots of metal removed and sonic checking, imo, is a must Beefier bottom end, filled pan rail, etc Standard 340 type top end, so unlike 59 degree r3 blocks, roller lifters drop right in. They can take a lot of punishment. They are my favorite LA 59 degree block I Ran one at 4.100 700 horse years ago, that block is still in use Virgin block like you have is worth 3k + all day
69 Dart GTS A4 Silver All steel, flat factory hood, 3350 race weight 418 BPE factory replacement headed stroker Best so far, 10.48 127 1.44 best 60 foot. 6..64 at 103.16
[Re: B3422W5]
#3146868
05/26/23 01:09 AM
05/26/23 01:09 AM
Posts: 6,047 Melbourne , Australia
LA360
The 360 has 273 style rockers on it. Nothing uncommon there, as they were an alternative to buying roller rockers. Check that it has a solid tappet, rather than a preloaded hydraulic lifter.
The main selling point for the X block is that most roller lifters are a total drop in. Otherwise they're very similar to the early R blocks that came much later. Both blocks were machined with factory type tooling, just the casting had a lot more material where it matter.
You shouldn't have any trouble selling the X block, they're defintely sought after by the 59* crowd.
Alan Jones
[Re: migsBIG]
#3147321
05/28/23 11:03 PM
05/28/23 11:03 PM
migsBIG
San Jose,CA
Will post more info Tuesday. By chance, how would someone build up a block like this? High compression? Turbo? Blower? Nitrus?
[Re: migsBIG]
#3147700
05/30/23 09:10 PM
05/30/23 09:10 PM
LA360
They're an early race block, they're not siamese bore, so they're not going to handle a bunch of boost or a bunch of nitrous. Having the extra meat around the crankshaft will certainly help. The builds I have seen have usually been W5 or Indy headed strokers that make around 700hp
Alan Jones
[Re: migsBIG]
#3147859
05/31/23 04:26 PM
05/31/23 04:26 PM
Posts: 10,475 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Useless junk. Contact me, and I'll do you a solid and take it off your hands for a fair price. I need a boat anchor.
