318 small block ‘X’ block. Give me the dirty little details.
#3146836
05/25/23 08:14 PM
05/25/23 08:14 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
So long story short, was told this guy has a TA/AAR block and turns out to be a 1979 dated Mopar Performance over the counter block and has been sitting in his shop since the early 1980’s. Now I know a little something about the ‘R’ blocks produced later on, but nothing on the ‘X’ ones. It looks to have a standard bore set of 340 pistons, but the guy will double check the bores when he gets back home tomorrow. The 4-bolt mains look super beefy and dang, it felt heavy like a 440 block.
So my question is: Are these desirable? How much hp/tq are they good for? Is there a value to owning one or just sell it? Thanks in advance.
Re: 318 small block ‘X’ block. Give me the dirty little details.
[Re: migsBIG]
#3146839
05/25/23 08:40 PM
05/25/23 08:40 PM
Posts: 11,712 Portage,michigan
B3422W5
Portage,michigan
Ultra desirable Come 2 or 4 bolt Come 3.91 bore, have seen them check good for use at 4.125 bore. But each one can be a bit different. So, to get to a standard 4.04 340 bore, need lots of metal removed and sonic checking, imo, is a must Beefier bottom end, filled pan rail, etc Standard 340 type top end, so unlike 59 degree r3 blocks, roller lifters drop right in. They can take a lot of punishment. They are my favorite LA 59 degree block I Ran one at 4.100 700 horse years ago, that block is still in use Virgin block like you have is worth 3k + all day
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3146868
05/26/23 01:09 AM
05/26/23 01:09 AM
Posts: 6,142 Melbourne , Australia
LA360
The 360 has 273 style rockers on it. Nothing uncommon there, as they were an alternative to buying roller rockers. Check that it has a solid tappet, rather than a preloaded hydraulic lifter.
The main selling point for the X block is that most roller lifters are a total drop in. Otherwise they're very similar to the early R blocks that came much later. Both blocks were machined with factory type tooling, just the casting had a lot more material where it matter.
You shouldn't have any trouble selling the X block, they're defintely sought after by the 59* crowd.
Alan Jones
[Re: migsBIG]
#3147321
05/28/23 11:03 PM
05/28/23 11:03 PM
migsBIG
San Jose,CA
Will post more info Tuesday. By chance, how would someone build up a block like this? High compression? Turbo? Blower? Nitrus?
[Re: migsBIG]
#3147700
05/30/23 09:10 PM
05/30/23 09:10 PM
LA360
They're an early race block, they're not siamese bore, so they're not going to handle a bunch of boost or a bunch of nitrous. Having the extra meat around the crankshaft will certainly help. The builds I have seen have usually been W5 or Indy headed strokers that make around 700hp
Alan Jones
[Re: migsBIG]
#3147859
05/31/23 04:26 PM
05/31/23 04:26 PM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Useless junk. Contact me, and I'll do you a solid and take it off your hands for a fair price. I need a boat anchor.
